6920 works in 32 bit ubuntu 10.04 not in 64 bit 10.04
Postby thelamer » Wed Jun 01, 2011 12:51 pm
I have 2 identical systems with identical drivers built. On the 32 bit the tuner is working;
scan -c
dumping lists (2 services)
[0001]                   (0x0001) 00: PCR == V   V 0x01f5 A 0x1f41 (eng)
[0002]                   (0x0002) 00: PCR 0x1fff
On 64 bit;
scan -c
dumping lists (0 services)
Done.
Dmesg for these devices is identical and all the scanning programs I call upon seem to be able to hit the api they are just not able to lock. Just to test I swapped the hard drives in these systems to rule out system failure or RF issues and the 32 bit drive works in the 64 bit build.
What command line arguments can I use to test these streams ? These are coming out of an ip enscapsulator with the following settings;
Frequency 1259000
FEC 2/3
SymbolRate 13205000
Modulation psk8
Rolloff 0.20
thelamer
Re: 6920 works in 32 bit ubuntu 10.04 not in 64 bit 10.04
Postby thelamer » Wed Jun 01, 2011 1:22 pm
Update I figures out how to test lock from the command line;
WIth 32 bit I get lock with szap:
szap -n 1
reading channels from file '/root/.szap/channels.conf'
zapping to 1 '[0001]':
sat 0, frequency = 0 MHz H, symbolrate 0, vpid = 0x01f5, apid = 0x1f41 sid = 0x0001
FE_SET_FRONTEND failed: Invalid argument
status 1f | signal 0026 | snr 0000 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0025 | snr 0000 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0025 | snr 00d0 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
While in 64 bit:
szap -n 1
status 00 | signal 0046 | snr 0000 | ber 00000000 | unc 00000000 |
Again I want to emphasize that if I swap the hard drives I get the same result. It cannot be RF or hardware.
thelamer
