uk. ch4 hd picture problems
Postby desauld » Sun Feb 19, 2012 4:53 am
Hi guys. Ok I have my card up and running ok appart from this issue. Ch4 hd has some weird picture issue. I use windows 7 media center 64 bit on a new build e350 AMD. All other hd stuff, inc bluray is great, but ch4 hd has strange picture problems. If the people don't move in the picture its fine, but as soon as they move I get breakup. Any advice?
Cheers des
desauld
Re: uk. ch4 hd picture problems
Postby steven » Sun Feb 19, 2012 6:26 pm
Hi desauld
This maybe your Decorder's problem ,so would you mind just using another decorder to a have a test.
Postby desauld » Mon Feb 20, 2012 4:57 am
I'm not sure how to change decoder. How can I do that. Thanks for the help.
desauld
Postby desauld » Tue Feb 21, 2012 6:11 am
Do you mean to use a different program than Windows media center? Cheers des
desauld
Postby steven » Tue Feb 21, 2012 8:58 am
yes,you can,would you mind use the latest progdvb to have a test with uk.ch4 hd channel.
Postby desauld » Sun Mar 25, 2012 10:37 am
Sorry its been so long, but I still have this problem even with different programs eg supplied viewer. I have installed the newest video drivers and catilists, but still exactly the same. Why just this channel. Cheers des
desauld
Postby steven » Wed Mar 28, 2012 11:43 am
Hi desauld
Would you mind give us the detail video and audio decoder you are using?
Postby AlunS » Wed Apr 11, 2012 12:00 am
For what it's worth, I have the same problem with a number of different TV clients and codecs. Other people on the internet seem to have the same problem, but it seems to be limited to those with AMD/ATI Radeon graphics cards, including the built-in GPU in the AMD E350.
Other HD (i.e. h264) channels work well (BBC HD, BBC 1 HD, ITV HD etc.) work OK, but there is a small (one off) glitch a few seconds after switching to the channel, but after that it's fine.
Why Channel 4 HD gives so many problems I don't know.
AlunS
Postby SergioDanielG » Wed Apr 11, 2012 12:28 am
AlunS Wrote:Other HD (i.e. h264) channels work well (BBC HD, BBC 1 HD, ITV HD etc.) work OK, but there is a small (one off) glitch a few seconds after switching to the channel, but after that it's fine.
Unfortunately, I can't access to these channel. But if you can use some card in linux, using dvbsnoop you'll can see wich type of codec it's needed. ( I don't know if there are same application to see that in windows)
Or if you can tune and lock this TP, with ffmpeg you can see type of file and codec needed.
Best regards
SergioDanielG
Postby AlunS » Wed Apr 11, 2012 4:55 pm
It's H.264 just like all the other channels that do work (albeit with the slight startup glitch I mentioned).
AlunS
