Power issue?
Power issue?
Postby Neil948 » Sat Feb 18, 2012 5:06 pm
Hi there,
I have recently purchased the TBS8920 pci card from amazon.
FYI:- I am using:-
HP proliant ML110 G5 server with Windows XP sp3 installed.
I only have one pci slot.
Now when i plug anything into this slot everything works and is great however when i plug in the TBS8920 pci card there is suddenly no power taken from the PSU and i have to remove the card and turn the power off then back on to get it to reboot once the card is out and power is restarted the system starts up fine once the card is back in the system will not boot again.
Is there something that i need to try?
Thanks in advance.
Neil948
Re: Power issue?
Postby steven » Tue Feb 21, 2012 2:10 pm
Hi Neil948
is this problem solved now?Do you have updated your BIOS?
and would you mind having a test with other computer?
Re: Power issue?
Postby Neil948 » Thu Mar 01, 2012 11:36 pm
As this system is an active web server I have stopped using it and switched to a different system
Neil948
