No DiseqC-switching - card bad?
Postby donald24 » Wed May 25, 2011 12:27 am
Hello there,
I have just popped in this brand-new card, and I am wondering, why there is no DiseqC-switching. I have tried with several programs, ie. Dvbviewer, ProgDVB, and then Transedit with customized (in fact a double and Triple DiseqC-switch) commands and it stays only on DiseqC-(A/B) . So (A/A) is not possible. My hardware-receiver hooked on the same LNB has no problems, as the Mystique-Card which was before on these two cables, the 6981 has.
So I am 100% confident, that I did everything possible to make it switch to the other satellite, but I had no luck. Should I RMA the card, or is there hope?
Running Win7 x64 with SP1.
Thanks,
Don
donald24
Re: No DiseqC-switching - card bad?
Postby steven » Thu Jun 02, 2011 6:01 pm
Hi Sorry for the inconvenience,
pls try our oem dvbdream:
here is the link :http://www.tbsdtv.com/download/common/dvbdream_setup_v15g_oem.rar
