QBOX Windows 7 x64 blue screen or hangup ProgDVB
Postby psk » Fri Jul 02, 2010 3:55 am
Hi!
I have bought QBOX DVB-S2 (called here as Q-Q DVB-S2 USB tunner) and i have problem with Windows 7 x64 - drivers are installed propelly, but ProgDVB tell me (x64) that tunner cannot be started - via BDA. When i take ProgDVB x86 (32bit) it hangs with blue screen with notice about q2box.sys.
Help please.
Regards.
psk
Re: QBOX Windows 7 x64 blue screen or hangup ProgDVB
Postby cody » Fri Jul 02, 2010 9:59 am
hi, i answered to your mail you sent to our technical support e-mail address, but i will put the answer here, because other people can ask the same:
while 64bit version of ProgDVB is still not supported (but it will be), 32bit version is working completely fine with Q-Box S2 in Windows 7 64bit. did you install and use device module for ProgDVB that is found on the installation CD of Q-Box S2?
--cody
Postby troll » Thu Jul 08, 2010 11:46 pm
I read that Q-box is from TBS and Q-Q box not , on my Win 7 the ProgDVB 6.34.02 work fine.
Regard
troll
troll
Postby cody » Fri Jul 09, 2010 9:17 am
troll, thank you and you're correct, because now i noticed that user "psk" posted his driver is called "q2box.sys" and that device is not made by TBS.
