tbs6981fe - attach failed [solved]
Postby LLSmurf » Sun Feb 05, 2012 3:50 am
I've tried to get this card working with my ASUS AT3IONT-I and a 350W power supply (incl. PCI-E 6-pin plug attached to the TBS6981).
So far I have the same errors no matter whether I use a VDR-distribution like yavdr or easyvdr (32-bit) or (currently) debian squeeze with 64bit.
I followed the README_TBS6981 instructions in the linux-tbs-drivers_111118.zip from this website.
Excerpt from dmesg (complete dmesg as attachment):
[    7.802266] cx25840 3-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[    7.809813] cx23885_dvb_register() allocating 1 frontend(s)
[    7.809824] cx23885[0]: cx23885 based dvb card
[    7.963713] TurboSight TBS 6981 Frontend 0 Attaching...
[    7.963945] TurboSight TBS 6981 Frontend:
[    7.963948]  tbs6981fe - attach failed
[    7.971839] BUG: unable to handle kernel NULL pointer dereference at 00000000000000b0
[    7.971998] IP: [<ffffffffa0f01026>] tbsfe_attach+0x0/0x1a [tbsfe]
[    7.972114] PGD 5cc52067 PUD 37b3a067 PMD 0
[    7.972302] Oops: 0002 [#1] SMP
[    7.972442] last sysfs file: /sys/module/i2c_core/initstate
[    7.972498] CPU 1
[    7.972592] Modules linked in: tbsfe tbs6981fe(P) snd_hda_codec_nvhdmi snd_hda_codec_realtek ir_lirc_codec lirc_dev cx25840 ir_mce_kbd_decoder ir_sony_decoder ir_jvc_decoder ir_rc6_decoder snd_hda_intel ir_rc5_decoder cx23885(+) ir_nec_decoder snd_hda_codec rc_core cx2341x videobuf_dma_sg snd_hwdep videobuf_dvb snd_pcm dvb_core snd_seq videobuf_core snd_timer v4l2_common videodev media snd_seq_device v4l2_compat_ioctl32 nvidia(P) btcx_risc tveeprom snd evdev pcspkr shpchp soundcore asus_atk0110 i2c_nforce2 wmi pci_hotplug snd_page_alloc i2c_core processor button ext3 jbd mbcache sg sr_mod cdrom sd_mod crc_t10dif ata_generic ahci r8169 libata ohci_hcd mii ehci_hcd scsi_mod usbcore nls_base thermal thermal_sys [last unloaded: scsi_wait_scan]
[    7.975616] Pid: 564, comm: modprobe Tainted: P           2.6.32-5-amd64 #1 System Product Name
[    7.975616] RIP: 0010:[<ffffffffa0f01026>]  [<ffffffffa0f01026>] tbsfe_attach+0x0/0x1a [tbsfe]
[    7.975616] RSP: 0018:ffff88005cc7bc10  EFLAGS: 00010282
[    7.975616] RAX: ffffffffa0f01026 RBX: 0000000000000002 RCX: 0000000000000000
[    7.975616] RDX: 0000000000000001 RSI: ffffffffa0e412cb RDI: 0000000000000000
[    7.975616] RBP: ffff88005ef1e000 R08: ffff88005cc7bba8 R09: 0000000000000000
[    7.975616] R10: ffff88005ef1e000 R11: ffffffffa0f01150 R12: ffff88005ef1e000
[    7.975616] R13: ffff88005dcc9000 R14: ffff88005ef1f0fc R15: ffff88005ef1f120
[    7.975616] FS:  00007fe9a48bc700(0000) GS:ffff880001880000(0000) knlGS:0000000000000000
[    7.975616] CS:  0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[    7.975616] CR2: 00000000000000b0 CR3: 000000005d438000 CR4: 00000000000006e0
[    7.975616] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[    7.975616] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[    7.975616] Process modprobe (pid: 564, threadinfo ffff88005cc7a000, task ffff88005d731c40)
[    7.975616] Stack:
[    7.975616]  ffffffffa0e3458d 00000000000000f0 ffff88005ef1f120 0000000000000000
[    7.975616] <0> ffff88005ef1eb78 ffff88005ef1f0fc ffff88005ef1f130 0000000000000000
[    7.975616] <0> ffff88005ef1eb78 0000000000000000 0000000000000000 00000000fffee2a8
[    7.975616] Call Trace:
[    7.975616]  [<ffffffffa0e3458d>] ? cx23885_dvb_register+0x11d5/0x1f10 [cx23885]
[    7.975616]  [<ffffffffa0193470>] ? i2c_transfer+0xb1/0xc0 [i2c_core]
[    7.975616]  [<ffffffffa0193e48>] ? i2c_master_send+0x37/0x43 [i2c_core]
[    7.975616]  [<ffffffffa0e7fb67>] ? cx25840_write4+0x38/0x3d [cx25840]
[    7.975616]  [<ffffffff8106502a>] ? autoremove_wake_function+0x0/0x2e
[    7.975616]  [<ffffffffa0e805e8>] ? common_s_io_pin_config+0x211/0x21c [cx25840]
[    7.975616]  [<ffffffffa0e2ca7b>] ? cx23885_ir_init+0x285/0x2ac [cx23885]
[    7.975616]  [<ffffffffa0e8270b>] ? cx25840_load_fw+0x65/0x82 [cx25840]
[    7.975616]  [<ffffffffa0e3b990>] ? cx23885_initdev+0x934/0xc58 [cx23885]
[    7.975616]  [<ffffffff811a2b86>] ? local_pci_probe+0x12/0x16
[    7.975616]  [<ffffffff811a37d6>] ? pci_device_probe+0xc0/0xe9
[    7.975616]  [<ffffffff8122130c>] ? driver_probe_device+0xa3/0x14b
[    7.975616]  [<ffffffff81221403>] ? __driver_attach+0x4f/0x6f
[    7.975616]  [<ffffffff812213b4>] ? __driver_attach+0x0/0x6f
[    7.975616]  [<ffffffff81220bdb>] ? bus_for_each_dev+0x43/0x74
[    7.975616]  [<ffffffff8122059b>] ? bus_add_driver+0xaf/0x1f8
[    7.975616]  [<ffffffff812216bb>] ? driver_register+0xa7/0x111
[    7.975616]  [<ffffffffa0e4c000>] ? cx23885_init+0x0/0x35 [cx23885]
[    7.975616]  [<ffffffff811a3a1c>] ? __pci_register_driver+0x50/0xb8
[    7.975616]  [<ffffffff8100a065>] ? do_one_initcall+0x64/0x174
[    7.975616]  [<ffffffff8107ab60>] ? sys_init_module+0xc5/0x21a
[    7.975616]  [<ffffffff81010b42>] ? system_call_fastpath+0x16/0x1b
[    7.975616] Code: <48> c7 87 b0 00 00 00 25 10 f0 a0 48 c7 87 50 01 00 00 00 10 f0 a0
[    7.975616] RIP  [<ffffffffa0f01026>] tbsfe_attach+0x0/0x1a [tbsfe]
[    7.975616]  RSP <ffff88005cc7bc10>
[    7.980852] ---[ end trace 84190799f477384e ]---
Please have a look at the attached data and please let me know of any idea, how to solve this. I currently assume a hardware problem and would ask TBS for a replacement, but maybe I miss something.
uname -a:
Linux hdvdr 2.6.32-5-amd64 #1 SMP Mon Jan 16 16:22:28 UTC 2012 x86_64 GNU/Linux
dmesg (as attachment)
lspci -vvnn (as attachment)
Thank you,
LLSmurf
lspci.zip
zipped "lspci -vvnn" output
(1.87 KiB) Downloaded 327 times
dmesg.zip
zipped dmesg output
(13.59 KiB) Downloaded 343 times
LLSmurf
Re: tbs6981fe - attach failed
Postby LLSmurf » Wed Feb 08, 2012 3:32 am
just to keep other potential readers updated.
TBS Support says, this as a hardware fault of the card.
CU,
LLSmurf
LLSmurf
