Problems compiling the driver for TBS6921
Postby Guido » Sat Apr 30, 2011 12:01 am
I am running yaVDR 0.30 which is an VDR on Ubuntu 10.04
Trying to compile the driver for the 6921 I get some warings:
MODPOST 420 modules
WARNING: could not find /home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/.tbs6980ctrl.o.cmd for /home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/tbs6980ctrl.o
WARNING: could not find /home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/.tbs6921fe_driver.o.cmd for /home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/tbs6921fe_driver.o
WARNING: could not find /home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/.tbs6980fe_driver.o.cmd for /home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/tbs6980fe_driver.o
WARNING: could not find /home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/.tbs6981fe_driver.o.cmd for /home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/tbs6981fe_driver.o
WARNING: "snd_aci_get_aci" [/home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/radio-miropcm20.ko] undefined!
WARNING: "snd_aci_cmd" [/home/XXXX/linux-s2api-tbs6921_v1.24.1/linux-s2api-tbs6921/v4l/radio-miropcm20.ko] undefined!
Which is probably the reason why the card can not be used with following message in the log
"You're board isn't known (yet) to the driver"
I am pretty shure I followed the instructions correctly.
Yes, I did run as root (sudo su)
Does anyone have an idea what is going wrong?
btw. there seems to be a little problem in the documentation, since you changed the tbs-x86.sh I think it needs to be called from the linux-s2api-tbs6921 directory and not from the v4l directory
cp ./v4l/tbs6980ctrl.o.x86 ./v4l/tbs6980ctrl.o
Guido
