Using MCE Remote Control
Postby atkinsonline » Sun Jan 22, 2012 9:24 pm
I've just fitted the TBS6280 in a Windows 7 64 bit PC and using Windows Media Center. The TV Card is working fine and the TBS remote is working but I'd like to know if it is possible to use a standard MCE remote because the MCE remote has much better buttons for controlling Media Center software. The TBS remote, although it works, it is far from ideal with Media Center.
John.
atkinsonline
Re: Using MCE Remote Control
Postby Hucknallred » Thu Feb 09, 2012 5:36 pm
It will be fine, it's designed for MCE, I use one myself with no problems.
Get one with the coloured text buttons, so you can browse the digital teletext.
Hucknallred
Postby Reeso1983 » Thu Aug 16, 2012 1:20 am
I'm in the same situation as the original poster.
But I'm failing to see how you get the IR Receiver attached to the card to use an MCE Remote? I can only get it to respond to the TBS Remote...
Any help is appreciated.
Craig.
Reeso1983
