Problem with DVBviewer's signal quality meter
Postby gersch07 » Sun Apr 17, 2011 8:32 am
I bought a TBS 6920 over amazon last week and the card seems to be working quite nicely with DVBviewer Pro 4.6.0.1. The only annoying thing is that the signal quality meter shows always 98%, independently of the transponder and even if there is no transponder selected. I'm using the driver version 1.0.4.9. Does anybody else have this problem? Is there a way to fix it?
Thus I can't use it as a sat finder.
This card originally should replace my old Technotrend TT-budget 3200, which is working without any problems. I'm using a new system with an Intel P67 chipset (ASUS Sabertooth).
Thanks for your help in advance!
gersch07
Re: Problem with DVBviewer's signal quality meter
Postby steven » Mon Apr 18, 2011 10:39 am
Hi,This value is read from the chip,and the chip's value whether is good or not,we can not judge it.
Sorry about this.
Postby jw300 » Thu Jun 02, 2011 10:51 pm
DVBViewer Pro doesn't report signal quality, only strength. Use Transedit instead, or DVBViewer GE.
jw300
Postby barnsbury » Tue Apr 29, 2014 11:09 pm
I am having exactly the same problem.
TBS 6925 with latest drivers - 1.01.22
The signal level always says 98%. So, this is clearly a bug.
barnsbury
