Dvb s2 usb box
Dvb s2 usb box
Postby droid » Thu Jan 19, 2012 8:06 am
Hi i a from the uk so hope you can help out my system i have a sky dish which is plugged into the qbox via coxial cable all works fine but i am not recieving any hd hannels and i am constantly getting a no tv signal which does not happen with my other set top box
can you please help me resolve this and can you recommned a softwore over media center
alos can you help me install a dvb t memory stick and then add it to windows media thanks
btw i a m using media center
droid
Re: Dvb s2 usb box
Postby droid » Thu Jan 19, 2012 11:40 pm
where is the support in this forum its been 24 hours and still no reoly whats wrong with tbsdtv why dont you support the people that brought your products how about helping out
come on now this is ridicous
why is there a no signal on most channels when used with media player im sure qbox supports media player does it not if not it should do media player is alomst on all pc so whats the problem here please explain qbox team i have paid a lot of money for this small box it was not cheap and no its not even fuctioning properly why
also why does the guide not show up on all channels why does media player keep pointing out no turner found when i sitch off the pc the next day most hd channels are not there i thought this was a hd box thats why i paid for it
Even if a hd channel does work after 1 mins if displays a message no tv signal found whats going wrong with q box
also my sky dish works with my set top box so why not qbox whats the problem here is the qbox a badly designed product?
if ypur going to blame windows media plyaer suggest anther media center thats better tham media player they are not media player has the best fuction i would stick with media player unless there is one that does exactly the same fuctions as media player
come on tbsdtv forum support here
droid
Re: Dvb s2 usb box
Postby steven » Wed Feb 01, 2012 4:32 pm
Hi droid
Sorry for the delay reply,Jan 18 to Feb 1 is our vacation. :)
From what you say would you mind tell use what's your Qbox type? QBox or QBox2 ,Qbox3,Qbox5922 ?
and which HD TP you want to watch?
Can you give us more information,the detail Transport which sat?
