TBS6280 install on mythbuntu 11.10
Postby damienmcguigan » Tue Jan 17, 2012 2:44 am
Hi all, I had a TBS6920 (DVB-S2) which worked perfectly. However, I am moving house to somewhere with just freeview so I decided to get a TBS6280 for DVB-T2. I have followed the instructions from various places including here and the readme included in the downloaded drivers. I have to follow the linuxtv guide to correct permissions and then run ./v4l/tbs-x86_r3.sh as I am running kernel 3+.
Whenever I try 'make' I get the following:
make -C /home/dbnshb/Downloads/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory `/home/dbnshb/Downloads/tbs/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
make[1]: execvp: scripts/make_makefile.pl: Permission denied
Updating/Creating .config
/bin/sh: ./scripts/make_kconfig.pl: Permission denied
make[1]: *** No rule to make target `.myconfig', needed by `config-compat.h'.  Stop.
make[1]: Leaving directory `/home/dbnshb/Downloads/tbs/linux-tbs-drivers/v4l'
make: *** [all] Error 2
Can anyone help?
damienmcguigan
Re: TBS6280 install on mythbuntu 11.10
Postby damienmcguigan » Tue Jan 17, 2012 5:22 am
problem sorted, had to chmod +x the scripts
damienmcguigan
