tbs 6920 has a compatibility issue with the msi motherboards
Postby george » Sat Jun 19, 2010 6:22 pm
I've just bought this dvb card and found the card isn't compatible with the msi motherboard k9n neo .i mean every time am trying to acquire the signal through this card, my system crashes. Not just me ,but a few people who had these types of msi motherboards, got the same problem as well. What's the solution?
george
Re: tbs 6920 has a compatibility issue with the msi motherbo
Postby cody » Mon Jun 21, 2010 10:42 am
you can try with updating your motherboard's BIOS to the latest version. however, we have in our database 4 (out of total 5) cases exactly like yours in which BIOS update didn't help (all of those cases are solved with replacing the motherboard) and 3 of them are with Asrock motherboards and 1 with MSI , but all of them are with nVidia chipset based motherboards. please, note that it's not some general incompatibility with nVidia chipsets, because on other motherboards with the same nVidia chipset there are no any problems. i guess maybe those Asrock and MSI boards that are affected doesn't provide good power to the slots or something else is wrong on them.
Postby george » Mon Jun 21, 2010 10:06 pm
tanks for the information, so it's true if I'm simply using the "tv tuner usb" like tbs "5980", there would be no more incompatibility with the msi motherboard . is it so?
george
