Diseqc
Diseqc
Postby Notsteve » Tue Apr 12, 2011 3:27 am
I have 2 setups. The first one is a virtual machine running windows 7 ultimate, the other is a core2duo desktop machine running windows 7 ultimate also. I run the latest drivers from tbs.
On the virtual machine, it seems that diseqc is working properly in fastsatfinder, mytheatre and dvbdream.
On the desktop, I can't get the diseqc to switch in any of these applications. I'm not sure if I set something up differently on the virtual machine, but it seems it worked right out of the box.
Anyone have any ideas? Is there something in win7 that needs to be enabled for diseqc to work?
Notsteve
