TBS 6984 driver issue 1.0.1.8
Postby Shummi » Sat Jan 07, 2012 11:34 pm
After i updated my TBS 6984 to v.1.0.1.8, port C and D don't work.
I have tried to restore Win7 to before update, but it still dosn't work.
Any suggestions??
/BR Shummi
Shummi
Re: TBS 6984 driver issue 1.0.1.8
Postby Shummi » Sun Jan 08, 2012 2:42 pm
I have measured the voltage of each port
the idle is
A 1,1V
B 1,1V
C 19,3V
D 1,1
When i eg. start IP tool at the different ports i get.
A 13,4V
B 13,4V
C 19,3V
D 1,1V
So it is showing the same, port C and D are bad, it think the is defect.
Can anyone confirm?
Shummi
Postby steven » Mon Jan 09, 2012 10:41 am
Hi Shummi
Would you mind use the older driver to have a test ,is it ok?
And We just have test V 1.0.1.8 Driver it shows ok.
So would you mind have a test both new driver and older driver.
Postby Shummi » Tue Jan 10, 2012 12:54 am
Hi Steven
I already done that, there isn't any logic in this, i tested after each line, with same result.
the 7. Jan.
11 to 13 i recorded a show
13.30 i updated the Driver to 1.0.1.8
13.45 port C and D malfunctioned
- roll back to 1.0.1.5
- restart
- power down, wait one minute, re powered
- run system restore to before driver update
- Deleted Driver and files, restart, installed 1.0.1.0
- powered off - pressed the card manically in place - but didn't take it out
- installed IP Tool - and tested - C and D - no signal
the 8. Jan.
- powerd up
- tested with IP Tool - measured voltage - see old post
- disasambeled the PC - cleaned it with compressed air - mounted DVBcard
***** and it worked ****** i can't explain it ??????
BR Shummi
The joy was short
After writing this mail i tried to watch live TV, and now PORT C and D malfunction again.
Should i sent it for replacement or do you have any other approach?
/Shummi
Shummi
Postby steven » Tue Jan 10, 2012 9:56 am
Hi Shummi
It is so strange,maybe the card have broken.
and would you mind have a test like this.
- powerd up measure C and D tuner Voltage:
C tuner: 0V
D tuner: 0V
- tested with IP Tool only with C and D tuner, lock with H TP and V TP - measured these voltage ,and tell us the
report like this.
H TP V TP
C tuner: 18V 13V
D tuner: 18V 13V
Postby Shummi » Wed Jan 11, 2012 12:53 am
I get C 19,3
D 1,1
I dosen't change if i change V to H and press Lock
If i try on port A and B i get 13,4 and 18,4
/Shummi
Shummi
Postby steven » Wed Jan 11, 2012 9:44 am
Hi Shummi
From your test report. it shows that your card have broken,
You can contact our support<support@tbsdtv.com> to get a replacement.
