No signal but card is found
Postby Daepilin » Sat Jan 07, 2012 8:08 pm
hio,
since yesterday i have a problem with my tbs6920. i just got a new tv so i had to redo the wireing and since then my card doesn't work anymore. I already tried to use a normal reciever on that cable and that worked like a charm. Windows hardwaremanager shows no problem with the card but i don't get a signal in DVBViewer, whatever i try ( at the start i had the same settings that i had before redoing the wirering but no signal at all... well, the signal display shows 98% but i don't get picture or sound and when clicking the signal meter it says ( at sound and video): no data/connected
kaffeine under ubuntu showed "no availiable dvb device"...
important: before removing the cable i closed dvb viewer so that should have been no problem ( at least i hope so).
channel search shows good signal but doesn't find channels. ( i deleted one to do this test but the software doesn't find it again)
Daepilin
Re: No signal but card is found
Postby steven » Tue Jan 10, 2012 2:02 pm
Can you have a check with the signal with other receiver?and have a test with TBS6920 in other computer.
If the signal is ok,and other computer can not too.
maybe the card have broken.
