lirc don`t work on Ubuntu 11.10
Postby romanb » Sat Jan 07, 2012 4:52 am
i have the tbs6981 Card, and installed sucessfully the drivers from the homepage.
The Card works fine with DVB-S, DVB-S2, but i had problems with the infrared on the card.
The Log messages looks good, no error messages, but i can't send any signal.
Test with 'irw' was negative, no event/signal.
I have no idea why i don't get any signals
dmesg and syslog says that all is OK
output from dmesg
[ 11.497787] cx23885 driver version 0.0.3 loaded
[ 11.497865] cx23885 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 11.498370] CORE cx23885[0]: subsystem: 6981:8888, board: TurboSight TBS 6981 [card=33,autodetected]
[ 12.242592] cx25840 3-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
[ 13.425459] cx25840 3-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[ 13.432971] cx23885_dvb_register() allocating 1 frontend(s)
[ 13.432982] cx23885[0]: cx23885 based dvb card
[ 13.518819] DVB: registering new adapter (cx23885[0])
[ 13.546489] cx23885_dvb_register() allocating 1 frontend(s)
[ 13.546497] cx23885[0]: cx23885 based dvb card
[ 13.632034] DVB: registering new adapter (cx23885[0])
[ 13.659407] cx23885_dev_checkrevision() Hardware revision = 0xa5
[ 13.659415] cx23885[0]/0: found at 0000:01:00.0, rev: 4, irq: 16, latency: 0, mmio: 0xfe800000
[ 13.659425] cx23885 0000:01:00.0: setting latency timer to 64
[ 13.684263] input: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:04.0/0000:01:00.0/rc/rc1/input8
[ 13.687782] rc1: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:04.0/0000:01:00.0/rc/rc1
[ 13.687975] input: MCE IR Keyboard/Mouse (cx23885) as /devices/virtual/input/input9
[ 13.688196] rc rc1: lirc_dev: driver ir-lirc-codec (cx23885) registered at minor = 1
lircd output in /var/log/syslog
Jan 6 21:29:09 medianix lircd-0.9.0[2775]: lircd(devinput) ready, using /var/run/lirc/lircd
Jan 6 21:29:16 medianix lircd-0.9.0[2775]: accepted new client on /var/run/lirc/lircd
Jan 6 21:29:16 medianix lircd-0.9.0[2775]: initializing '/dev/input/tbs-ir'
Jan 6 21:29:29 medianix lircd-0.9.0[2775]: removed client
Jan 6 21:29:29 medianix lircd-0.9.0[2775]: closing '/dev/input/tbs-ir'
the only thing i found was
Jan 6 21:26:55 medianix kernel: [ 95.965323] cx25840 3-0044: IR receiver hardware FIFO overrun
and
Jan 6 22:14:28 medianix kernel: [ 396.753202] cx23885[0]: failed to set up deferred work for AV Core/IR interrupt. Interrupt is disabled and won't be re-enabled
System was an AMD E-350, with Ubuntu 11.10 64bit Installation. Kernel 3.0.0.14
TBS-Driver linux-tbs-drivers_111118.zip
Any idea's or solution ?
greetings
Roman
romanb
