TBS6981 vs. TBS6984 signal quality
Postby micke » Mon Jan 02, 2012 3:09 am
I have tried to change from a TBS6981 to a TBS6984 card.
However the signal quality seems to differ, which makes a swap a downgrade.
Conditions:
    Same PC-powersupply for both cards.
    Quad LNB, where on of the cables is slightly (6-10m) longer.
    Command line: ./szap-s2 -a 0 -H -c thor.conf -S1 "TV" -O25 -M5 -C34
    Thor 5/6 satelite (europe)
    Signal level is always reported as 74%, independet of cable length.
    BER is always reported 0 on both cards, independent of cable length.
    no option line for any card in modules.conf
    111118 linux driver
    There are no visible picture errors when using my TBS6981 receiver.
    There are no visible picture errors when using a Sagem DVB-S2 receiver
    There are visible reception error on TBS6984.
    All inputs on the TBS6984 gives ~ same snr when same LNA is used for testing
snr is always reported as 100% for TBS6981, independent of cable length.
snr is reported as 97.2% on average for TBS6984 for the shorter cable.
snr is reported as 95.4% on average for TBS6984 for the longer cable.
Are there less power supply rejection on the TBS6984 which can cause this issues?
Are there any options that could be tested?
Best regards
Micke
micke
Re: TBS6981 vs. TBS6984 signal quality
Postby stefb » Sun Jan 15, 2012 5:23 pm
Hello I have the same kind of issues, mainly on S2 HD channels on Astra 19.2
I replaced a Tevii card (which was working perfectly) with the TBS6984, and I observe some lags and squares
reception level is at 74%
I'm using VDR 1.7.22 / yavdr on Ubuntu 10.04 with stock kernel 2.6.32-37-generic-pae
Stephane.
Here's the output of my dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.32-37-generic-pae (buildd@vernadsky) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #81-Ubuntu SMP Fri Dec 2 22:24:22 UTC 2011 (Ubuntu 2.6.32-37.81-generic-pae 2.6.32.49+drm33.21)
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   NSC Geode by NSC
[    0.000000]   Cyrix CyrixInstead
[    0.000000]   Centaur CentaurHauls
[    0.000000]   Transmeta GenuineTMx86
[    0.000000]   Transmeta TransmetaCPU
[    0.000000]   UMC UMC UMC UMC
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009cc00 (usable)
[    0.000000]  BIOS-e820: 000000000009cc00 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 00000000bff70000 (usable)
[    0.000000]  BIOS-e820: 00000000bff70000 - 00000000bff7e000 (ACPI data)
[    0.000000]  BIOS-e820: 00000000bff7e000 - 00000000bffd0000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000bffd0000 - 00000000c0000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[    0.000000]  BIOS-e820: 00000000ffe00000 - 0000000100000000 (reserved)
[    0.000000]  BIOS-e820: 0000000100000000 - 0000000140000000 (usable)
[    0.000000] DMI present.
[    0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] last_pfn = 0x140000 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-DFFFF write-protect
[    0.000000]   E0000-EFFFF write-through
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask F00000000 write-back
[    0.000000]   1 base 100000000 mask FC0000000 write-back
[    0.000000]   2 base 0C0000000 mask FC0000000 uncachable
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] e820 update range: 00000000c0000000 - 0000000100000000 (usable) ==> (reserved)
[    0.000000] Scanning 0 areas for low memory corruption
[    0.000000] modified physical RAM map:
[    0.000000]  modified: 0000000000000000 - 0000000000010000 (reserved)
[    0.000000]  modified: 0000000000010000 - 000000000009cc00 (usable)
[    0.000000]  modified: 000000000009cc00 - 00000000000a0000 (reserved)
[    0.000000]  modified: 00000000000e4000 - 0000000000100000 (reserved)
[    0.000000]  modified: 0000000000100000 - 00000000bff70000 (usable)
[    0.000000]  modified: 00000000bff70000 - 00000000bff7e000 (ACPI data)
[    0.000000]  modified: 00000000bff7e000 - 00000000bffd0000 (ACPI NVS)
[    0.000000]  modified: 00000000bffd0000 - 00000000c0000000 (reserved)
[    0.000000]  modified: 00000000fee00000 - 00000000fee01000 (reserved)
[    0.000000]  modified: 00000000ffe00000 - 0000000100000000 (reserved)
[    0.000000]  modified: 0000000100000000 - 0000000140000000 (usable)
[    0.000000] initial memory mapped : 0 - 00e00000
[    0.000000] init_memory_mapping: 0000000000000000-000000002f1fe000
[    0.000000] NX (Execute Disable) protection: active
[    0.000000]  0000000000 - 0000200000 page 4k
[    0.000000]  0000200000 - 002f000000 page 2M
[    0.000000]  002f000000 - 002f1fe000 page 4k
[    0.000000] kernel direct mapping tables up to 2f1fe000 @ 10000-16000
[    0.000000] RAMDISK: 37723000 - 37fef166
[    0.000000] Allocated new RAMDISK: 00942000 - 0120e166
[    0.000000] Move RAMDISK from 0000000037723000 - 0000000037fef165 to 00942000 - 0120e165
[    0.000000] ACPI: RSDP 000faff0 00024 (v02 ACPIAM)
[    0.000000] ACPI: XSDT bff70100 00064 (v01 _ASUS_ Notebook 04000906 MSFT 00000097)
[    0.000000] ACPI: FACP bff70290 000F4 (v03 _ASUS_ Notebook 04000906 MSFT 00000097)
[    0.000000] ACPI: DSDT bff70440 09721 (v01  A0986 A0986000 00000000 INTL 20060113)
[    0.000000] ACPI: FACS bff7e000 00040
[    0.000000] ACPI: SLIC 000ff200 00176 (v01 _ASUS_ Notebook 20090827 MSFT 00000097)
[    0.000000] ACPI: APIC bff70390 0006C (v01 _ASUS_ OEMAPIC  04000906 MSFT 00000097)
[    0.000000] ACPI: MCFG bff70400 0003C (v01 _ASUS_ OEMMCFG  04000906 MSFT 00000097)
[    0.000000] ACPI: OEMB bff7e040 00089 (v01 _ASUS_ AMI_OEM  04000906 MSFT 00000097)
[    0.000000] ACPI: HPET bff79b70 00038 (v01 _ASUS_ OEMHPET  04000906 MSFT 00000097)
[    0.000000] ACPI: OSFR bff79bb0 000B0 (v01 _ASUS_ OEMOSFR  04000906 MSFT 00000097)
[    0.000000] ACPI: SSDT bff7f040 00A7C (v01 DpgPmm    CpuPm 00000012 INTL 20060113)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 4366MB HIGHMEM available.
[    0.000000] 753MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 2f1fe000
[    0.000000]   low ram: 0 - 2f1fe000
[    0.000000]   node 0 low ram: 00000000 - 2f1fe000
[    0.000000]   node 0 bootmap 00012000 - 00017e40
[    0.000000] (9 early reservations) ==> bootmem [0000000000 - 002f1fe000]
[    0.000000]   #0 [0000000000 - 0000001000]   BIOS data page ==> [0000000000 - 0000001000]
[    0.000000]   #1 [0000001000 - 0000002000]    EX TRAMPOLINE ==> [0000001000 - 0000002000]
[    0.000000]   #2 [0000006000 - 0000007000]       TRAMPOLINE ==> [0000006000 - 0000007000]
[    0.000000]   #3 [0000100000 - 0000939858]    TEXT DATA BSS ==> [0000100000 - 0000939858]
[    0.000000]   #4 [000009cc00 - 0000100000]    BIOS reserved ==> [000009cc00 - 0000100000]
[    0.000000]   #5 [000093a000 - 000094121c]              BRK ==> [000093a000 - 000094121c]
[    0.000000]   #6 [0000010000 - 0000012000]          PGTABLE ==> [0000010000 - 0000012000]
[    0.000000]   #7 [0000942000 - 000120e166]      NEW RAMDISK ==> [0000942000 - 000120e166]
[    0.000000]   #8 [0000012000 - 0000018000]          BOOTMAP ==> [0000012000 - 0000018000]
[    0.000000] found SMP MP-table at [c00ff780] ff780
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x0002f1fe
[    0.000000]   HighMem  0x0002f1fe -> 0x00140000
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[3] active PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009c
[    0.000000]     0: 0x00000100 -> 0x000bff70
[    0.000000]     0: 0x00100000 -> 0x00140000
[    0.000000] On node 0 totalpages: 1048316
[    0.000000] free_area_init_node: node 0, pgdat c07d8e00, node_mem_map c1210200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3948 pages, LIFO batch:0
[    0.000000]   Normal zone: 1476 pages used for memmap
[    0.000000]   Normal zone: 187450 pages, LIFO batch:31
[    0.000000]   HighMem zone: 8733 pages used for memmap
[    0.000000]   HighMem zone: 846677 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[    0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[    0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 24
[    0.000000] PM: Registered nosave memory: 000000000009c000 - 000000000009d000
[    0.000000] PM: Registered nosave memory: 000000000009d000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[    0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[    0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:3ee00000)
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 15 pages/cpu @c3c00000 s39736 r0 d21704 u524288
[    0.000000] pcpu-alloc: s39736 r0 d21704 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1038075
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-37-generic-pae root=UUID=c087b698-9a0c-413a-bc49-42e8b306e04a ro vmalloc=256m quiet noresume nohz=off acpi_enforce_resources=lax pcie_aspm=off
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Enabling fast FPU save and restore... done.
[    0.000000] Enabling unmasked SIMD FPU exception support... done.
[    0.000000] Initializing CPU#0
[    0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240
[    0.000000] allocated 26214080 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (0002f1fe:00140000)
[    0.000000] Memory: 4106888k/5242880k available (4833k kernel code, 85160k reserved, 2220k data, 684k init, 3421640k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff1d000 - 0xfffff000   ( 904 kB)
[    0.000000]     pkmap   : 0xffa00000 - 0xffc00000   (2048 kB)
[    0.000000]     vmalloc : 0xef9fe000 - 0xff9fe000   ( 256 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef1fe000   ( 753 MB)
[    0.000000]       .init : 0xc07e4000 - 0xc088f000   ( 684 kB)
[    0.000000]       .data : 0xc05b877f - 0xc07e3788   (2220 kB)
[    0.000000]       .text : 0xc0100000 - 0xc05b877f   (4833 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:2304 nr_irqs:440
[    0.000000] Extended CMOS year: 2000
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] hpet clockevent registered
[    0.000000] Fast TSC calibration using PIT
[    0.000000] Detected 3199.329 MHz processor.
[    0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 6398.65 BogoMIPS (lpj=12797316)
[    0.004014] Security Framework initialized
[    0.004029] AppArmor: AppArmor initialized
[    0.004033] Mount-cache hash table entries: 512
[    0.004117] Initializing cgroup subsys ns
[    0.004120] Initializing cgroup subsys cpuacct
[    0.004123] Initializing cgroup subsys memory
[    0.004127] Initializing cgroup subsys devices
[    0.004129] Initializing cgroup subsys freezer
[    0.004130] Initializing cgroup subsys net_cls
[    0.004144] CPU: L1 I cache: 32K, L1 D cache: 32K
[    0.004146] CPU: L2 cache: 3072K
[    0.004148] CPU: Physical Processor ID: 0
[    0.004149] CPU: Processor Core ID: 0
[    0.004152] mce: CPU supports 6 MCE banks
[    0.004158] CPU0: Thermal monitoring enabled (TM2)
[    0.004160] using mwait in idle threads.
[    0.004164] Performance Events: Core2 events, Intel PMU driver.
[    0.004168] ... version:                2
[    0.004169] ... bit width:              40
[    0.004170] ... generic registers:      2
[    0.004171] ... value mask:             000000ffffffffff
[    0.004173] ... max period:             000000007fffffff
[    0.004174] ... fixed-purpose events:   3
[    0.004175] ... event mask:             0000000700000003
[    0.004179] Checking 'hlt' instruction... OK.
[    0.022009] ACPI: Core revision 20090903
[    0.036006] ftrace: converting mcount calls to 0f 1f 44 00 00
[    0.036009] ftrace: allocating 22365 entries in 44 pages
[    0.040039] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.040335] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.081453] CPU0: Intel(R) Core(TM)2 Quad CPU    Q9400  @ 2.66GHz stepping 0a
[    0.084001] APIC calibration not consistent with PM-Timer: 155ms instead of 100ms
[    0.084001] APIC delta adjusted to PM-Timer: 2499904 (3899794)
[    0.084001] Booting processor 1 APIC 0x1 ip 0x6000
[    0.008000] Initializing CPU#1
[    0.008000] CPU: L1 I cache: 32K, L1 D cache: 32K
[    0.008000] CPU: L2 cache: 3072K
[    0.008000] CPU: Physical Processor ID: 0
[    0.008000] CPU: Processor Core ID: 1
[    0.008000] CPU1: Thermal monitoring enabled (TM2)
[    0.168105] CPU1: Intel(R) Core(TM)2 Quad CPU    Q9400  @ 2.66GHz stepping 0a
[    0.168110] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[    0.172079] Booting processor 2 APIC 0x2 ip 0x6000
[    0.008000] Initializing CPU#2
[    0.008000] CPU: Processor Core ID: 2
[    0.008000] CPU2: Thermal monitoring enabled (TM2)
[    0.260036] CPU2: Intel(R) Core(TM)2 Quad CPU    Q9400  @ 2.66GHz stepping 0a
[    0.260041] checking TSC synchronization [CPU#0 -> CPU#2]: passed.
[    0.264055] Booting processor 3 APIC 0x3 ip 0x6000
[    0.008000] Initializing CPU#3
[    0.008000] CPU: Processor Core ID: 3
[    0.008000] CPU3: Thermal monitoring enabled (TM2)
[    0.352104] CPU3: Intel(R) Core(TM)2 Quad CPU    Q9400  @ 2.66GHz stepping 0a
[    0.352109] checking TSC synchronization [CPU#0 -> CPU#3]: passed.
[    0.356009] Brought up 4 CPUs
[    0.356011] Total of 4 processors activated (25598.08 BogoMIPS).
[    0.357792] CPU0 attaching sched-domain:
[    0.357795]  domain 0: span 0-1 level MC
[    0.357797]   groups: 0 1
[    0.357799]   domain 1: span 0-3 level CPU
[    0.357801]    groups: 0-1 (cpu_power = 2048) 2-3 (cpu_power = 2048)
[    0.357807] CPU1 attaching sched-domain:
[    0.357808]  domain 0: span 0-1 level MC
[    0.357809]   groups: 1 0
[    0.357812]   domain 1: span 0-3 level CPU
[    0.357813]    groups: 0-1 (cpu_power = 2048) 2-3 (cpu_power = 2048)
[    0.357817] CPU2 attaching sched-domain:
[    0.357818]  domain 0: span 2-3 level MC
[    0.357820]   groups: 2 3
[    0.357822]   domain 1: span 0-3 level CPU
[    0.357824]    groups: 2-3 (cpu_power = 2048) 0-1 (cpu_power = 2048)
[    0.357828] CPU3 attaching sched-domain:
[    0.357829]  domain 0: span 2-3 level MC
[    0.357830]   groups: 3 2
[    0.357833]   domain 1: span 0-3 level CPU
[    0.357834]    groups: 2-3 (cpu_power = 2048) 0-1 (cpu_power = 2048)
[    0.357928] devtmpfs: initialized
[    0.357928] regulator: core version 0.5
[    0.357928] Time: 23:48:47  Date: 01/14/12
[    0.357928] NET: Registered protocol family 16
[    0.357928] EISA bus registered
[    0.357928] Trying to unpack rootfs image as initramfs...
[    0.357928] ACPI: bus type pci registered
[    0.357928] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[    0.357928] PCI: Not using MMCONFIG.
[    0.357928] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=7
[    0.357928] PCI: Using configuration type 1 for base access
[    0.357928] bio: create slab <bio-0> at 0
[    0.360296] ACPI: EC: Look up EC in DSDT
[    0.362171] ACPI: Executed 1 blocks of module-level executable AML code
[    0.370122] ACPI: Interpreter enabled
[    0.370126] ACPI: (supports S0 S1 S3 S4 S5)
[    0.370141] ACPI: Using IOAPIC for interrupt routing
[    0.370176] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[    0.372210] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
[    0.372211] PCI: Using MMCONFIG for extended config space
[    0.377587] ACPI Warning: Incorrect checksum in table [OEMB] - 01, should be 00 (20090903/tbutils-314)
[    0.377687] ACPI: No dock devices found.
[    0.377797] ACPI: PCI Root Bridge [PCI0] (0000:00)
[    0.377864] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.377867] pci 0000:00:01.0: PME# disabled
[    0.377903] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[    0.377905] pci 0000:00:06.0: PME# disabled
[    0.377955] pci 0000:00:1a.0: reg 20 io port: [0xa800-0xa81f]
[    0.378010] pci 0000:00:1a.1: reg 20 io port: [0xa880-0xa89f]
[    0.378064] pci 0000:00:1a.2: reg 20 io port: [0xac00-0xac1f]
[    0.378122] pci 0000:00:1a.7: reg 10 32bit mmio: [0xf8fffc00-0xf8ffffff]
[    0.378166] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[    0.378169] pci 0000:00:1a.7: PME# disabled
[    0.378201] pci 0000:00:1b.0: reg 10 64bit mmio: [0xf8ff8000-0xf8ffbfff]
[    0.378233] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.378235] pci 0000:00:1b.0: PME# disabled
[    0.378283] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.378286] pci 0000:00:1c.0: PME# disabled
[    0.378337] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.378340] pci 0000:00:1c.2: PME# disabled
[    0.378390] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.378392] pci 0000:00:1c.4: PME# disabled
[    0.378443] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.378445] pci 0000:00:1c.5: PME# disabled
[    0.378488] pci 0000:00:1d.0: reg 20 io port: [0xa080-0xa09f]
[    0.378542] pci 0000:00:1d.1: reg 20 io port: [0xa400-0xa41f]
[    0.378597] pci 0000:00:1d.2: reg 20 io port: [0xa480-0xa49f]
[    0.378654] pci 0000:00:1d.7: reg 10 32bit mmio: [0xf8fff800-0xf8fffbff]
[    0.378698] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.378702] pci 0000:00:1d.7: PME# disabled
[    0.378804] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003)
[    0.378808] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 4700 (mask 001f)
[    0.378858] pci 0000:00:1f.2: reg 10 io port: [0x9c00-0x9c07]
[    0.378862] pci 0000:00:1f.2: reg 14 io port: [0x9880-0x9883]
[    0.378866] pci 0000:00:1f.2: reg 18 io port: [0x9800-0x9807]
[    0.378870] pci 0000:00:1f.2: reg 1c io port: [0x9480-0x9483]
[    0.378874] pci 0000:00:1f.2: reg 20 io port: [0x9400-0x941f]
[    0.378879] pci 0000:00:1f.2: reg 24 32bit mmio: [0xf8ffe800-0xf8ffefff]
[    0.378903] pci 0000:00:1f.2: PME# supported from D3hot
[    0.378905] pci 0000:00:1f.2: PME# disabled
[    0.378927] pci 0000:00:1f.3: reg 10 64bit mmio: [0xf8fff400-0xf8fff4ff]
[    0.378937] pci 0000:00:1f.3: reg 20 io port: [0x400-0x41f]
[    0.378972] pci 0000:01:00.0: reg 10 32bit mmio: [0xf9000000-0xf9ffffff]
[    0.378979] pci 0000:01:00.0: reg 14 64bit mmio pref: [0xd0000000-0xdfffffff]
[    0.378985] pci 0000:01:00.0: reg 1c 64bit mmio pref: [0xce000000-0xcfffffff]
[    0.378990] pci 0000:01:00.0: reg 24 io port: [0xbc00-0xbc7f]
[    0.378994] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xfab00000-0xfab7ffff]
[    0.379037] pci 0000:01:00.1: reg 10 32bit mmio: [0xfabfc000-0xfabfffff]
[    0.379101] pci 0000:00:01.0: bridge io port: [0xb000-0xbfff]
[    0.379103] pci 0000:00:01.0: bridge 32bit mmio: [0xf9000000-0xfabfffff]
[    0.379106] pci 0000:00:01.0: bridge 64bit mmio pref: [0xce000000-0xdfffffff]
[    0.379140] pci 0000:02:00.0: reg 10 64bit mmio: [0xfacfe000-0xfacfffff]
[    0.379181] pci 0000:02:00.0: PME# supported from D0 D3hot
[    0.379184] pci 0000:02:00.0: PME# disabled
[    0.379224] pci 0000:00:06.0: bridge 32bit mmio: [0xfac00000-0xfacfffff]
[    0.379259] pci 0000:00:1c.0: bridge 64bit mmio pref: [0xf7f00000-0xf7ffffff]
[    0.379304] pci 0000:05:00.0: reg 10 64bit mmio: [0xfaf00000-0xfaffffff]
[    0.379375] pci 0000:05:00.0: supports D1 D2
[    0.379377] pci 0000:05:00.0: PME# supported from D0 D1 D2
[    0.379381] pci 0000:05:00.0: PME# disabled
[    0.379428] pci 0000:00:1c.2: bridge 32bit mmio: [0xfaf00000-0xfaffffff]
[    0.379470] pci 0000:04:00.0: reg 10 io port: [0xdc00-0xdc07]
[    0.379476] pci 0000:04:00.0: reg 14 io port: [0xd880-0xd883]
[    0.379483] pci 0000:04:00.0: reg 18 io port: [0xd800-0xd807]
[    0.379489] pci 0000:04:00.0: reg 1c io port: [0xd480-0xd483]
[    0.379496] pci 0000:04:00.0: reg 20 io port: [0xd400-0xd40f]
[    0.379502] pci 0000:04:00.0: reg 24 32bit mmio: [0xfaeffc00-0xfaefffff]
[    0.379537] pci 0000:04:00.0: supports D1
[    0.379538] pci 0000:04:00.0: PME# supported from D0 D1 D3hot
[    0.379542] pci 0000:04:00.0: PME# disabled
[    0.379579] pci 0000:00:1c.4: bridge io port: [0xd000-0xdfff]
[    0.379582] pci 0000:00:1c.4: bridge 32bit mmio: [0xfae00000-0xfaefffff]
[    0.379634] pci 0000:03:00.0: reg 10 64bit mmio: [0xfadfc000-0xfadfffff]
[    0.379641] pci 0000:03:00.0: reg 18 io port: [0xc800-0xc8ff]
[    0.379664] pci 0000:03:00.0: reg 30 32bit mmio pref: [0xfadc0000-0xfaddffff]
[    0.379699] pci 0000:03:00.0: supports D1 D2
[    0.379700] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.379704] pci 0000:03:00.0: PME# disabled
[    0.379739] pci 0000:00:1c.5: bridge io port: [0xc000-0xcfff]
[    0.379742] pci 0000:00:1c.5: bridge 32bit mmio: [0xfad00000-0xfadfffff]
[    0.379772] pci 0000:07:00.0: reg 10 io port: [0xe800-0xe8ff]
[    0.379777] pci 0000:07:00.0: reg 14 32bit mmio: [0xfebff000-0xfebfffff]
[    0.379812] pci 0000:07:00.0: supports D2
[    0.379813] pci 0000:07:00.0: PME# supported from D0 D2 D3hot D3cold
[    0.379816] pci 0000:07:00.0: PME# disabled
[    0.379849] pci 0000:07:01.0: reg 10 32bit mmio: [0xfb000000-0xfbffffff]
[    0.379917] pci 0000:07:01.2: reg 10 32bit mmio: [0xfc000000-0xfcffffff]
[    0.379978] pci 0000:07:01.4: reg 10 32bit mmio: [0xfd000000-0xfdffffff]
[    0.380052] pci 0000:07:02.0: reg 10 32bit mmio: [0xfebf8000-0xfebfbfff]
[    0.380058] pci 0000:07:02.0: reg 14 io port: [0xe400-0xe4ff]
[    0.380079] pci 0000:07:02.0: reg 30 32bit mmio pref: [0xfebc0000-0xfebdffff]
[    0.380099] pci 0000:07:02.0: supports D1 D2
[    0.380101] pci 0000:07:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.380104] pci 0000:07:02.0: PME# disabled
[    0.380132] pci 0000:07:03.0: reg 10 32bit mmio: [0xfebfe000-0xfebfefff]
[    0.380170] pci 0000:07:03.0: supports D1 D2
[    0.380172] pci 0000:07:03.0: PME# supported from D0 D1 D2 D3hot
[    0.380175] pci 0000:07:03.0: PME# disabled
[    0.380209] pci 0000:00:1e.0: transparent bridge
[    0.380212] pci 0000:00:1e.0: bridge io port: [0xe000-0xefff]
[    0.380215] pci 0000:00:1e.0: bridge 32bit mmio: [0xfb000000-0xfebfffff]
[    0.380238] pci_bus 0000:00: on NUMA node 0
[    0.380241] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.380351] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
[    0.380392] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
[    0.380431] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[    0.380506] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P6._PRT]
[    0.380547] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT]
[    0.380586] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[    0.380644] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
[    0.393076] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[    0.393156] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[    0.393234] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[    0.393312] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[    0.393390] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.393469] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[    0.393546] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
[    0.393625] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[    0.393702] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.393707] vgaarb: loaded
[    0.393773] SCSI subsystem initialized
[    0.393779] libata version 3.00 loaded.
[    0.393779] usbcore: registered new interface driver usbfs
[    0.393779] usbcore: registered new interface driver hub
[    0.393779] usbcore: registered new device driver usb
[    0.393841] ACPI: WMI: Mapper loaded
[    0.393841] PCI: Using ACPI for IRQ routing
[    0.393841] NetLabel: Initializing
[    0.393841] NetLabel:  domain hash size = 128
[    0.393841] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.393841] NetLabel:  unlabeled traffic allowed by default
[    0.393841] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[    0.393841] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[    0.393841] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[    0.404152] Switching to clocksource tsc
[    0.405592] AppArmor: AppArmor Filesystem Enabled
[    0.405607] pnp: PnP ACPI init
[    0.405622] ACPI: bus type pnp registered
[    0.407860] pnp: PnP ACPI: found 15 devices
[    0.407861] ACPI: ACPI bus type pnp unregistered
[    0.407864] PnPBIOS: Disabled by ACPI PNP
[    0.407873] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
[    0.407878] system 00:06: ioport range 0x290-0x29f has been reserved
[    0.407882] system 00:07: ioport range 0x4d0-0x4d1 has been reserved
[    0.407884] system 00:07: ioport range 0x800-0x87f has been reserved
[    0.407886] system 00:07: ioport range 0x500-0x57f has been reserved
[    0.407888] system 00:07: iomem range 0xfed08000-0xfed08fff has been reserved
[    0.407889] system 00:07: iomem range 0xfed1c000-0xfed1ffff has been reserved
[    0.407891] system 00:07: iomem range 0xfed20000-0xfed3ffff has been reserved
[    0.407893] system 00:07: iomem range 0xfed50000-0xfed8ffff has been reserved
[    0.407897] system 00:0a: iomem range 0xffc00000-0xffdfffff has been reserved
[    0.407901] system 00:0c: iomem range 0xfec00000-0xfec00fff could not be reserved
[    0.407903] system 00:0c: iomem range 0xfee00000-0xfee00fff has been reserved
[    0.407906] system 00:0d: iomem range 0xe0000000-0xefffffff has been reserved
[    0.407910] system 00:0e: iomem range 0x0-0x9ffff could not be reserved
[    0.407912] system 00:0e: iomem range 0xc0000-0xcffff could not be reserved
[    0.407913] system 00:0e: iomem range 0xe0000-0xfffff could not be reserved
[    0.407915] system 00:0e: iomem range 0x100000-0xbfffffff could not be reserved
[    0.407917] system 00:0e: iomem range 0xe0000000-0xffffffff could not be reserved
[    0.442600] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[    0.442602] pci 0000:00:01.0:   IO window: 0xb000-0xbfff
[    0.442605] pci 0000:00:01.0:   MEM window: 0xf9000000-0xfabfffff
[    0.442607] pci 0000:00:01.0:   PREFETCH window: 0x000000ce000000-0x000000dfffffff
[    0.442610] pci 0000:00:06.0: PCI bridge, secondary bus 0000:02
[    0.442612] pci 0000:00:06.0:   IO window: disabled
[    0.442614] pci 0000:00:06.0:   MEM window: 0xfac00000-0xfacfffff
[    0.442616] pci 0000:00:06.0:   PREFETCH window: disabled
[    0.442619] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:06
[    0.442621] pci 0000:00:1c.0:   IO window: 0x1000-0x1fff
[    0.442625] pci 0000:00:1c.0:   MEM window: 0xc0000000-0xc03fffff
[    0.442627] pci 0000:00:1c.0:   PREFETCH window: 0x000000f7f00000-0x000000f7ffffff
[    0.442632] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:05
[    0.442634] pci 0000:00:1c.2:   IO window: 0x2000-0x2fff
[    0.442637] pci 0000:00:1c.2:   MEM window: 0xfaf00000-0xfaffffff
[    0.442640] pci 0000:00:1c.2:   PREFETCH window: 0x000000c0400000-0x000000c05fffff
[    0.442645] pci 0000:00:1c.4: PCI bridge, secondary bus 0000:04
[    0.442647] pci 0000:00:1c.4:   IO window: 0xd000-0xdfff
[    0.442650] pci 0000:00:1c.4:   MEM window: 0xfae00000-0xfaefffff
[    0.442653] pci 0000:00:1c.4:   PREFETCH window: 0x000000c0600000-0x000000c07fffff
[    0.442657] pci 0000:00:1c.5: PCI bridge, secondary bus 0000:03
[    0.442659] pci 0000:00:1c.5:   IO window: 0xc000-0xcfff
[    0.442663] pci 0000:00:1c.5:   MEM window: 0xfad00000-0xfadfffff
[    0.442666] pci 0000:00:1c.5:   PREFETCH window: 0x000000c0800000-0x000000c09fffff
[    0.442670] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:07
[    0.442672] pci 0000:00:1e.0:   IO window: 0xe000-0xefff
[    0.442676] pci 0000:00:1e.0:   MEM window: 0xfb000000-0xfebfffff
[    0.442678] pci 0000:00:1e.0:   PREFETCH window: disabled
[    0.442688]   alloc irq_desc for 16 on node -1
[    0.442689]   alloc kstat_irqs on node -1
[    0.442693] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.442696] pci 0000:00:01.0: setting latency timer to 64
[    0.442700] pci 0000:00:06.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.442702] pci 0000:00:06.0: setting latency timer to 64
[    0.442707] pci 0000:00:1c.0: enabling device (0106 -> 0107)
[    0.442710]   alloc irq_desc for 17 on node -1
[    0.442711]   alloc kstat_irqs on node -1
[    0.442713] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    0.442716] pci 0000:00:1c.0: setting latency timer to 64
[    0.442721] pci 0000:00:1c.2: enabling device (0106 -> 0107)
[    0.442723]   alloc irq_desc for 18 on node -1
[    0.442724]   alloc kstat_irqs on node -1
[    0.442727] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    0.442729] pci 0000:00:1c.2: setting latency timer to 64
[    0.442735] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    0.442738] pci 0000:00:1c.4: setting latency timer to 64
[    0.442744] pci 0000:00:1c.5: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[    0.442747] pci 0000:00:1c.5: setting latency timer to 64
[    0.442751] pci 0000:00:1e.0: setting latency timer to 64
[    0.442754] pci_bus 0000:00: resource 0 io:  [0x00-0xffff]
[    0.442756] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[    0.442757] pci_bus 0000:01: resource 0 io:  [0xb000-0xbfff]
[    0.442759] pci_bus 0000:01: resource 1 mem: [0xf9000000-0xfabfffff]
[    0.442761] pci_bus 0000:01: resource 2 pref mem [0xce000000-0xdfffffff]
[    0.442762] pci_bus 0000:02: resource 1 mem: [0xfac00000-0xfacfffff]
[    0.442764] pci_bus 0000:06: resource 0 io:  [0x1000-0x1fff]
[    0.442765] pci_bus 0000:06: resource 1 mem: [0xc0000000-0xc03fffff]
[    0.442767] pci_bus 0000:06: resource 2 pref mem [0xf7f00000-0xf7ffffff]
[    0.442769] pci_bus 0000:05: resource 0 io:  [0x2000-0x2fff]
[    0.442770] pci_bus 0000:05: resource 1 mem: [0xfaf00000-0xfaffffff]
[    0.442772] pci_bus 0000:05: resource 2 pref mem [0xc0400000-0xc05fffff]
[    0.442773] pci_bus 0000:04: resource 0 io:  [0xd000-0xdfff]
[    0.442775] pci_bus 0000:04: resource 1 mem: [0xfae00000-0xfaefffff]
[    0.442777] pci_bus 0000:04: resource 2 pref mem [0xc0600000-0xc07fffff]
[    0.442778] pci_bus 0000:03: resource 0 io:  [0xc000-0xcfff]
[    0.442780] pci_bus 0000:03: resource 1 mem: [0xfad00000-0xfadfffff]
[    0.442782] pci_bus 0000:03: resource 2 pref mem [0xc0800000-0xc09fffff]
[    0.442783] pci_bus 0000:07: resource 0 io:  [0xe000-0xefff]
[    0.442785] pci_bus 0000:07: resource 1 mem: [0xfb000000-0xfebfffff]
[    0.442786] pci_bus 0000:07: resource 3 io:  [0x00-0xffff]
[    0.442788] pci_bus 0000:07: resource 4 mem: [0x000000-0xffffffffffffffff]
[    0.442809] NET: Registered protocol family 2
[    0.442868] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.443051] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.443281] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.443398] TCP: Hash tables configured (established 131072 bind 65536)
[    0.443399] TCP reno registered
[    0.443445] NET: Registered protocol family 1
[    0.443566] pci 0000:01:00.0: Boot video device
[    0.443761] cpufreq-nforce2: No nForce2 chipset.
[    0.443777] Scanning for low memory corruption every 60 seconds
[    0.443836] audit: initializing netlink socket (disabled)
[    0.443843] type=2000 audit(1326584926.443:1): initialized
[    0.450462] highmem bounce pool size: 64 pages
[    0.450465] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.451399] VFS: Disk quotas dquot_6.5.2
[    0.451435] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.451795] fuse init (API version 7.13)
[    0.451848] msgmni has been set to 1340
[    0.452006] alg: No test for stdrng (krng)
[    0.452040] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.452042] io scheduler noop registered
[    0.452043] io scheduler anticipatory registered
[    0.452044] io scheduler deadline registered
[    0.452070] io scheduler cfq registered (default)
[    0.452171]   alloc irq_desc for 24 on node -1
[    0.452172]   alloc kstat_irqs on node -1
[    0.452178] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
[    0.452183] pcieport 0000:00:01.0: setting latency timer to 64
[    0.452241]   alloc irq_desc for 25 on node -1
[    0.452243]   alloc kstat_irqs on node -1
[    0.452246] pcieport 0000:00:06.0: irq 25 for MSI/MSI-X
[    0.452249] pcieport 0000:00:06.0: setting latency timer to 64
[    0.452314]   alloc irq_desc for 26 on node -1
[    0.452315]   alloc kstat_irqs on node -1
[    0.452320] pcieport 0000:00:1c.0: irq 26 for MSI/MSI-X
[    0.452325] pcieport 0000:00:1c.0: setting latency timer to 64
[    0.452407]   alloc irq_desc for 27 on node -1
[    0.452408]   alloc kstat_irqs on node -1
[    0.452413] pcieport 0000:00:1c.2: irq 27 for MSI/MSI-X
[    0.452419] pcieport 0000:00:1c.2: setting latency timer to 64
[    0.452501]   alloc irq_desc for 28 on node -1
[    0.452502]   alloc kstat_irqs on node -1
[    0.452507] pcieport 0000:00:1c.4: irq 28 for MSI/MSI-X
[    0.452513] pcieport 0000:00:1c.4: setting latency timer to 64
[    0.452595]   alloc irq_desc for 29 on node -1
[    0.452596]   alloc kstat_irqs on node -1
[    0.452601] pcieport 0000:00:1c.5: irq 29 for MSI/MSI-X
[    0.452607] pcieport 0000:00:1c.5: setting latency timer to 64
[    0.452668] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.452752] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.452823] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.452826] ACPI: Power Button [PWRB]
[    0.452855] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.452856] ACPI: Power Button [PWRF]
[    0.453347] ACPI: SSDT bff7e0d0 00235 (v01 DpgPmm  P001Ist 00000011 INTL 20060113)
[    0.453698] ACPI: SSDT bff7e9d0 004B2 (v01  PmRef  P001Cst 00003001 INTL 20060113)
[    0.454117] Monitor-Mwait will be used to enter C-1 state
[    0.454132] Monitor-Mwait will be used to enter C-2 state
[    0.454145] Monitor-Mwait will be used to enter C-3 state
[    0.454149] Marking TSC unstable due to TSC halts in idle
[    0.454183] processor LNXCPU:00: registered as cooling_device0
[    0.454468] ACPI: SSDT bff7e310 00235 (v01 DpgPmm  P002Ist 00000012 INTL 20060113)
[    0.454705] ACPI: SSDT bff7ee90 00085 (v01  PmRef  P002Cst 00003000 INTL 20060113)
[    0.455166] Switching to clocksource hpet
[    0.455216] processor LNXCPU:01: registered as cooling_device1
[    0.455542] ACPI: SSDT bff7e550 00235 (v01 DpgPmm  P003Ist 00000012 INTL 20060113)
[    0.455782] ACPI: SSDT bff7ef20 00085 (v01  PmRef  P003Cst 00003000 INTL 20060113)
[    0.456334] processor LNXCPU:02: registered as cooling_device2
[    0.456627] ACPI: SSDT bff7e790 00235 (v01 DpgPmm  P004Ist 00000012 INTL 20060113)
[    0.456867] ACPI: SSDT bff7efb0 00085 (v01  PmRef  P004Cst 00003000 INTL 20060113)
[    0.465787] processor LNXCPU:03: registered as cooling_device3
[    0.467556] isapnp: Scanning for PnP cards...
[    0.468423] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.468506] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.468804] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.469489] brd: module loaded
[    0.469796] loop: module loaded
[    0.469848] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[    0.469963] pata_acpi 0000:04:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.469985] pata_acpi 0000:04:00.0: setting latency timer to 64
[    0.469996] pata_acpi 0000:04:00.0: PCI INT A disabled
[    0.470181] Fixed MDIO Bus: probed
[    0.470202] PPP generic driver version 2.4.2
[    0.470220] tun: Universal TUN/TAP device driver, 1.6
[    0.470221] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.470273] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.470285] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    0.470291] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[    0.470294] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[    0.470316] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    0.470339] ehci_hcd 0000:00:1a.7: debug port 1
[    0.474213] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[    0.474224] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf8fffc00
[    0.492012] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    0.492066] usb usb1: configuration #1 chosen from 1 choice
[    0.492083] hub 1-0:1.0: USB hub found
[    0.492088] hub 1-0:1.0: 6 ports detected
[    0.492127]   alloc irq_desc for 23 on node -1
[    0.492128]   alloc kstat_irqs on node -1
[    0.492131] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[    0.492138] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[    0.492140] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[    0.492159] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    0.492180] ehci_hcd 0000:00:1d.7: debug port 1
[    0.496064] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[    0.496072] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf8fff800
[    0.503237] Freeing initrd memory: 9008k freed
[    0.512009] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    0.512066] usb usb2: configuration #1 chosen from 1 choice
[    0.512082] hub 2-0:1.0: USB hub found
[    0.512086] hub 2-0:1.0: 6 ports detected
[    0.512123] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.512135] uhci_hcd: USB Universal Host Controller Interface driver
[    0.512147] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.512151] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[    0.512153] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    0.512171] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    0.512195] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000a800
[    0.512250] usb usb3: configuration #1 chosen from 1 choice
[    0.512266] hub 3-0:1.0: USB hub found
[    0.512269] hub 3-0:1.0: 2 ports detected
[    0.512299]   alloc irq_desc for 21 on node -1
[    0.512300]   alloc kstat_irqs on node -1
[    0.512303] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[    0.512306] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[    0.512308] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    0.512327] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    0.512349] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000a880
[    0.512400] usb usb4: configuration #1 chosen from 1 choice
[    0.512416] hub 4-0:1.0: USB hub found
[    0.512419] hub 4-0:1.0: 2 ports detected
[    0.512448] uhci_hcd 0000:00:1a.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    0.512452] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[    0.512455] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[    0.512474] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[    0.512492] uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000ac00
[    0.512545] usb usb5: configuration #1 chosen from 1 choice
[    0.512562] hub 5-0:1.0: USB hub found
[    0.512566] hub 5-0:1.0: 2 ports detected
[    0.512593] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[    0.512596] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    0.512599] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.512618] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[    0.512636] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000a080
[    0.512688] usb usb6: configuration #1 chosen from 1 choice
[    0.512705] hub 6-0:1.0: USB hub found
[    0.512708] hub 6-0:1.0: 2 ports detected
[    0.512735]   alloc irq_desc for 19 on node -1
[    0.512736]   alloc kstat_irqs on node -1
[    0.512739] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    0.512742] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    0.512744] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    0.512762] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[    0.512785] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000a400
[    0.512838] usb usb7: configuration #1 chosen from 1 choice
[    0.512854] hub 7-0:1.0: USB hub found
[    0.512857] hub 7-0:1.0: 2 ports detected
[    0.512885] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    0.512888] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    0.512890] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    0.512914] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[    0.512931] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a480
[    0.512987] usb usb8: configuration #1 chosen from 1 choice
[    0.513002] hub 8-0:1.0: USB hub found
[    0.513006] hub 8-0:1.0: 2 ports detected
[    0.513077] PNP: No PS/2 controller found. Probing ports directly.
[    0.515656] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.515660] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.515711] mice: PS/2 mouse device common for all mice
[    0.515782] rtc_cmos 00:03: RTC can wake from S4
[    0.515805] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[    0.515824] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.515885] device-mapper: uevent: version 1.0.3
[    0.515948] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[    0.516030] device-mapper: multipath: version 1.1.0 loaded
[    0.516032] device-mapper: multipath round-robin: version 1.0.0 loaded
[    0.516102] EISA: Probing bus 0 at eisa.0
[    0.516106] Cannot allocate resource for EISA slot 1
[    0.516107] Cannot allocate resource for EISA slot 2
[    0.516121] EISA: Detected 0 cards.
[    0.516311] cpuidle: using governor ladder
[    0.516453] cpuidle: using governor menu
[    0.516721] TCP cubic registered
[    0.516818] NET: Registered protocol family 10
[    0.517324] NET: Registered protocol family 17
[    0.518212] Using IPI No-Shortcut mode
[    0.518259] registered taskstats version 1
[    0.518706]   Magic number: 12:249:858
[    0.518755] rtc_cmos 00:03: setting system clock to 2012-01-14 23:48:47 UTC (1326584927)
[    0.518757] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.518758] EDD information not available.
[    0.820418] isapnp: No Plug & Play device found
[    0.820433] Freeing unused kernel memory: 684k freed
[    0.820653] Write protecting the kernel text: 4836k
[    0.820708] Write protecting the kernel read-only data: 1884k
[    0.831681] udev: starting version 151
[    0.851315] sky2 driver version 1.25
[    0.851348] sky2 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    0.851360] sky2 0000:03:00.0: setting latency timer to 64
[    0.851380] sky2 0000:03:00.0: Yukon-2 EC Ultra chip revision 3
[    0.851457]   alloc irq_desc for 30 on node -1
[    0.851459]   alloc kstat_irqs on node -1
[    0.851470] sky2 0000:03:00.0: irq 30 for MSI/MSI-X
[    0.853550] sky2 eth0: addr 00:22:15:24:54:ac
[    0.859845] ahci 0000:00:1f.2: version 3.0
[    0.859861] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    0.859895]   alloc irq_desc for 31 on node -1
[    0.859897]   alloc kstat_irqs on node -1
[    0.859907] ahci 0000:00:1f.2: irq 31 for MSI/MSI-X
[    0.859966] ahci: SSS flag set, parallel bus scan disabled
[    0.860000] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
[    0.860014] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ccc ems sxs
[    0.860018] ahci 0000:00:1f.2: setting latency timer to 64
[    0.860637] usb 1-5: new high speed USB device using ehci_hcd and address 3
[    0.877245] pata_marvell 0000:04:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.877281] pata_marvell 0000:04:00.0: setting latency timer to 64
[    0.877330] scsi0 : pata_marvell
[    0.877413] scsi1 : pata_marvell
[    0.877437] ata1: PATA max UDMA/100 cmd 0xdc00 ctl 0xd880 bmdma 0xd400 irq 16
[    0.877439] ata2: PATA max UDMA/133 cmd 0xd800 ctl 0xd480 bmdma 0xd408 irq 16
[    0.878931] skge 0000:07:02.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    0.878969] skge 1.13 addr 0xfebf8000 irq 18 chip Yukon-Lite rev 9
[    0.879057] xor: automatically using best checksumming function: pIII_sse
[    0.879439] skge eth1: addr 00:22:15:24:5b:ed
[    0.880831] ohci1394 0000:07:03.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[    0.897004]    pIII_sse  : 12167.000 MB/sec
[    0.897006] xor: using function: pIII_sse (12167.000 MB/sec)
... skipped hd init
[    6.023478] async_tx: api initialized (async)
[    6.038550] input: Gyration Gyration RF Technology Receiver as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/input/input3
[    6.038635] gyration 0003:0C16:0002.0001: input,hiddev96,hidraw0: USB HID v1.10 Keyboard [Gyration Gyration RF Technology Receiver] on usb-0000:00:1a.0-2/input0
[    6.064633] input: Gyration Gyration RF Technology Receiver as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.1/input/input4
[    6.064725] gyration 0003:0C16:0002.0002: input,hiddev97,hidraw1: USB HID v1.20 Mouse [Gyration Gyration RF Technology Receiver] on usb-0000:00:1a.0-2/input1
[    7.026698] EXT4-fs (sda1): mounted filesystem with ordered data mode
[    7.271152] Adding 1333240k swap on /dev/sda5.  Priority:-1 extents:1 across:1333240k SS
[    7.314367] udev: starting version 151
[    7.394785] Warning: dev (tty1) tty->count(3) != #fd's(2) in tty_release_dev
[    7.426033] Linux agpgart interface v0.103
[    7.443335] tbs6922fe: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
[    7.443337] Disabling lock debugging due to kernel taint
[    7.446096] SAA716x TBS 0000:05:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    7.446103] SAA716x TBS 0000:05:00.0: setting latency timer to 64
[    7.457861] ISDN subsystem Rev: 1.1.2.3/1.1.2.3/1.1.2.2/1.1.2.3/1.1.2.2/1.1.2.2 loaded
[    7.460156] DVB: registering new adapter (SAA716x dvb adapter)
[    7.476746] wctdm 0000:07:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    7.476980] Freshmaker version: 73
[    7.477377] Freshmaker passed register test
[   10.187684] wcopenpci: Module loaded
[   10.190165] lp: driver loaded but no devices found
[   10.192656] TurboSight TBS 6984 Frontend 0 Attaching...
[   10.207079] xhci_hcd 0000:02:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[   10.207097] xhci_hcd 0000:02:00.0: setting latency timer to 64
[   10.207100] xhci_hcd 0000:02:00.0: xHCI Host Controller
[   10.207174] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 9
[   10.207276] xhci_hcd 0000:02:00.0: irq 16, io mem 0xfacfe000
[   10.210737] usb usb9: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor
[   10.210820] usb usb9: configuration #1 chosen from 1 choice
[   10.210823] xHCI xhci_add_endpoint called for root hub
[   10.210824] xHCI xhci_check_bandwidth called for root hub
[   10.210849] hub 9-0:1.0: USB hub found
[   10.210854] hub 9-0:1.0: 4 ports detected
[   11.217778] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[   11.217785] nvidia 0000:01:00.0: setting latency timer to 64
[   11.217789] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   11.217881] NVRM: loading NVIDIA UNIX x86 Kernel Module  260.19.36  Tue Jan 18 17:10:40 PST 2011
[   11.378544] IR NEC protocol handler initialized
[   11.379615] TurboSight TBS6984 DVB-S2 card port0 MAC=00:22:ab:90:09:b0
[   11.379619] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   11.379766] DVB: registering new adapter (SAA716x dvb adapter)
[   11.379993] TurboSight TBS 6984 Frontend 1 Attaching...
[   11.401977] dvb-usb: found a 'Intel CE9500 reference design' in warm state.
[   11.404375] Linux media interface: v0.10
[   11.408802] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[   11.409009] DVB: registering new adapter (Intel CE9500 reference design)
[   11.411671] Linux video capture interface: v2.00
[   11.426972] w83627ehf: Found W83667HG chip at 0x290
[   11.427000] ACPI: resource w83627ehf [0x295-0x296] conflicts with ACPI region HWRE [0x290-0x299]
[   11.427001] ACPI: This conflict may cause random problems and system instability
[   11.427003] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   11.441440] cx88/0: cx2388x v4l2 driver version 0.0.9 loaded
[   11.441486] cx8800 0000:07:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[   11.441736] cx88[0]: subsystem: 0070:9002, board: Hauppauge Nova-T DVB-T [card=18,autodetected], frontend(s): 1
[   11.441738] cx88[0]: TV tuner type 4, Radio tuner type -1
[   11.442387] DVB: registering adapter 2 frontend 0 (Zarlink ZL10353 DVB-T)...
[   11.443160] cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.9 loaded
[   11.455558] MXL5005S: Attached at address 0xc6
[   11.455786] dvb-usb: Intel CE9500 reference design successfully initialized and connected.
[   11.455814] usbcore: registered new interface driver dvb_usb_ce6230
[   11.462372] TurboSight TBS6984 DVB-S2 card port1 MAC=00:22:ab:90:09:b1
[   11.462375] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   11.462540] DVB: registering new adapter (SAA716x dvb adapter)
[   11.462776] TurboSight TBS 6984 Frontend 0 Attaching...
[   11.470230] IR RC5(x) protocol handler initialized
[   11.502992] IR RC6 protocol handler initialized
[   11.510091] IR JVC protocol handler initialized
[   11.534755] IR Sony protocol handler initialized
[   11.545112]   alloc irq_desc for 22 on node -1
[   11.545114]   alloc kstat_irqs on node -1
[   11.545120] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[   11.545155]   alloc irq_desc for 32 on node -1
[   11.545156]   alloc kstat_irqs on node -1
[   11.545163] HDA Intel 0000:00:1b.0: irq 32 for MSI/MSI-X
[   11.545181] HDA Intel 0000:00:1b.0: setting latency timer to 64
[   11.546590] TurboSight TBS6984 DVB-S2 card port2 MAC=00:22:ab:90:09:b2
[   11.546594] DVB: registering adapter 3 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   11.546728] DVB: registering new adapter (SAA716x dvb adapter)
[   11.546940] TurboSight TBS 6984 Frontend 1 Attaching...
[   11.566517] IR MCE Keyboard/mouse protocol handler initialized
[   11.571205] lirc_dev: IR Remote Control driver registered, major 249
[   11.572556] IR LIRC bridge handler initialized
[   11.599988] tveeprom 3-0050: Hauppauge model 90002, rev C176, serial# 149691
[   11.599991] tveeprom 3-0050: MAC address is 00:0d:fe:02:48:bb
[   11.599992] tveeprom 3-0050: tuner model is Thompson DTT7592 (idx 76, type 4)
[   11.599994] tveeprom 3-0050: TV standards ATSC/DVB Digital (eeprom 0x80)
[   11.599996] tveeprom 3-0050: audio processor is None (idx 0)
[   11.599998] tveeprom 3-0050: decoder processor is CX882 (idx 25)
[   11.599999] tveeprom 3-0050: has no radio, has IR receiver, has no IR transmitter
[   11.600001] cx88[0]: hauppauge eeprom: model=90002
[   11.629545] Registered IR keymap rc-hauppauge
[   11.629648] input: cx88 IR (Hauppauge Nova-T DVB-T as /devices/pci0000:00/0000:00:1e.0/0000:07:01.0/rc/rc0/input5
[   11.629703] rc0: cx88 IR (Hauppauge Nova-T DVB-T as /devices/pci0000:00/0000:00:1e.0/0000:07:01.0/rc/rc0
[   11.630062] TurboSight TBS6984 DVB-S2 card port3 MAC=00:22:ab:90:09:b3
[   11.630065] DVB: registering adapter 4 frontend 0 (TurboSight TBS 6984 DVBS/S2 frontend)...
[   11.630299] input: MCE IR Keyboard/Mouse (cx88xx) as /devices/virtual/input/input6
[   11.630349] rc rc0: lirc_dev: lirc_register_driver: sample_rate: 0
[   11.630372] rc rc0: lirc_dev: driver ir-lirc-codec (cx88xx) registered at minor = 0
[   11.630378] cx88[0]/0: found at 0000:07:01.0, rev: 5, irq: 17, latency: 64, mmio: 0xfb000000
[   11.630385] IRQ 17/cx88[0]: IRQF_DISABLED is not guaranteed on shared IRQs
[   11.630478] cx88[0]/0: registered device video0 [v4l2]
[   11.630502] cx88[0]/0: registered device vbi0
[   11.631197] cx88[0]/2: cx2388x 8802 Driver Manager
[   11.631214] cx88-mpeg driver manager 0000:07:01.2: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[   11.631220] cx88[0]/2: found at 0000:07:01.2, rev: 5, irq: 17, latency: 64, mmio: 0xfc000000
[   11.631222] IRQ 17/cx88[0]: IRQF_DISABLED is not guaranteed on shared IRQs
[   11.643979] cx88/2: cx2388x dvb driver version 0.0.9 loaded
[   11.643982] cx88/2: registering cx8802 driver, type: dvb access: shared
[   11.643985] cx88[0]/2: subsystem: 0070:9002, board: Hauppauge Nova-T DVB-T [card=18]
[   11.643987] cx88[0]/2: cx2388x based DVB/ATSC card
[   11.643989] cx8802_alloc_frontends() allocating 1 frontend(s)
[   11.680737] DVB: registering new adapter (cx88[0])
[   11.680740] DVB: registering adapter 5 frontend 0 (Conexant CX22702 DVB-T)...
[   11.727793] sky2 eth0: enabling interface
[   11.727864] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.950008] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input7
[   11.953145] HDA Intel 0000:01:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[   11.953148] hda_intel: Disable MSI for Nvidia chipset
[   11.953172] HDA Intel 0000:01:00.1: setting latency timer to 64
stefb
Postby stefb » Sun Jan 15, 2012 5:43 pm
And Here's lspci -vvnn
00:00.0 Host bridge [0600]: Intel Corporation 4 Series Chipset DRAM Controller [8086:2e20] (rev 02)
        Subsystem: ASUSTeK Computer Inc. Device [1043:82d3]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
        Latency: 0
        Capabilities: [e0] Vendor Specific Information <?>
        Kernel modules: intel-agp
00:01.0 PCI bridge [0604]: Intel Corporation 4 Series Chipset PCI Express Root Port [8086:2e21] (rev 02)
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Latency: 0, Cache Line Size: 32 bytes
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 0000b000-0000bfff
        Memory behind bridge: f9000000-fabfffff
        Prefetchable memory behind bridge: 00000000ce000000-00000000dfffffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR+ NoISA- VGA+ MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [88] Subsystem: ASUSTeK Computer Inc. Device [1043:82d3]
        Capabilities: [80] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [90] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable+
                Address: fee0f00c  Data: 4161
        Capabilities: [a0] Express (v2) Root Port (Slot+), MSI 00
                        ExtTag- RBE+ FLReset-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                LnkCap: Port #2, Speed 5GT/s, Width x16, ASPM L0s, Latency L0 <256ns, L1 <4us
                        ClockPM- Suprise- LLActRep- BwNot+
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
                LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt-
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surpise-
                        Slot #  0, PowerLimit 10.000000; Interlock- NoCompl-
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
                        Changed: MRL- PresDet+ LinkState-
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
                RootCap: CRSVisible-
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
        Capabilities: [100] Virtual Channel <?>
        Capabilities: [140] Root Complex Link <?>
        Kernel driver in use: pcieport
        Kernel modules: shpchp
00:06.0 PCI bridge [0604]: Intel Corporation 4 Series Chipset PCI Express Root Port [8086:2e29] (rev 02)
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        Memory behind bridge: fac00000-facfffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity- SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
        Capabilities: [88] Subsystem: Intel Corporation Device [8086:0000]
                Address: fee0f00c  Data: 4169
                LnkCap: Port #3, Speed 5GT/s, Width x8, ASPM L0s L1, Latency L0 <1us, L1 <4us
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk-
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt+ ABWMgmt-
                        Slot #  2, PowerLimit 10.000000; Interlock- NoCompl+
00:1a.0 USB Controller [0c03]: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4 [8086:3a37]
        Subsystem: ASUSTeK Computer Inc. Device [1043:82d4]
        Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Region 4: I/O ports at a800 [size=32]
        Capabilities: [50] Vendor Specific Information <?>
        Kernel driver in use: uhci_hcd
00:1a.1 USB Controller [0c03]: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5 [8086:3a38]
        Latency: 0
        Interrupt: pin B routed to IRQ 21
        Region 4: I/O ports at a880 [size=32]
00:1a.2 USB Controller [0c03]: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6 [8086:3a39]
        Latency: 0
        Interrupt: pin C routed to IRQ 18
        Region 4: I/O ports at ac00 [size=32]
00:1a.7 USB Controller [0c03]: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2 [8086:3a3c] (prog-if 20)
        Latency: 0
        Region 0: Memory at f8fffc00 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [58] Debug port: BAR=1 offset=00a0
        Capabilities: [98] Vendor Specific Information <?>
        Kernel driver in use: ehci_hcd
00:1b.0 Audio device [0403]: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller [8086:3a3e]
        Subsystem: ASUSTeK Computer Inc. Device [1043:8311]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 32
        Region 0: Memory at f8ff8000 (64-bit, non-prefetchable) [size=16K]
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable+
                Address: 00000000fee0f00c  Data: 41c1
        Capabilities: [70] Express (v1) Root Complex Integrated Endpoint, MSI 00
                        ExtTag- RBE- FLReset+
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #0, Speed unknown, Width x0, ASPM unknown, Latency L0 <64ns, L1 <1us
                        ClockPM- Suprise- LLActRep- BwNot-
                LnkCtl: ASPM Disabled; Disabled- Retrain- CommClk-
                LnkSta: Speed unknown, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
        Capabilities: [130] Root Complex Link <?>
        Kernel driver in use: HDA Intel
        Kernel modules: snd-hda-intel
00:1c.0 PCI bridge [0604]: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1 [8086:3a40]
        Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
        I/O behind bridge: 00001000-00001fff
        Memory behind bridge: c0000000-c03fffff
        Prefetchable memory behind bridge: 00000000f7f00000-00000000f7ffffff
        Capabilities: [40] Express (v1) Root Port (Slot+), MSI 00
                LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <256ns, L1 <4us
                        ClockPM- Suprise- LLActRep+ BwNot-
                LnkSta: Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surpise+
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
                        Changed: MRL- PresDet- LinkState-
        Capabilities: [80] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable+
                Address: fee0f00c  Data: 4171
        Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device [1043:82d4]
        Capabilities: [a0] Power Management version 2
        Capabilities: [180] Root Complex Link <?>
00:1c.2 PCI bridge [0604]: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 3 [8086:3a44]
        Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
        I/O behind bridge: 00002000-00002fff
        Memory behind bridge: faf00000-faffffff
        Prefetchable memory behind bridge: 00000000c0400000-00000000c05fffff
                LnkCap: Port #3, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <256ns, L1 <4us
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
                        Changed: MRL- PresDet+ LinkState+
                Address: fee0f00c  Data: 4179
00:1c.4 PCI bridge [0604]: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5 [8086:3a48]
        Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
        I/O behind bridge: 0000d000-0000dfff
        Memory behind bridge: fae00000-faefffff
        Prefetchable memory behind bridge: 00000000c0600000-00000000c07fffff
                DevCtl: Report errors: Correctable+ Non-Fatal- Fatal- Unsupported-
                LnkCap: Port #5, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <256ns, L1 <4us
                Address: fee0f00c  Data: 4181
00:1c.5 PCI bridge [0604]: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6 [8086:3a4a]
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: 0000c000-0000cfff
        Memory behind bridge: fad00000-fadfffff
        Prefetchable memory behind bridge: 00000000c0800000-00000000c09fffff
                LnkCap: Port #6, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <256ns, L1 <4us
                Address: fee0f00c  Data: 4189
00:1d.0 USB Controller [0c03]: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1 [8086:3a34]
        Latency: 0
        Interrupt: pin A routed to IRQ 23
        Region 4: I/O ports at a080 [size=32]
00:1d.1 USB Controller [0c03]: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2 [8086:3a35]
        Latency: 0
        Interrupt: pin B routed to IRQ 19
        Region 4: I/O ports at a400 [size=32]
00:1d.2 USB Controller [0c03]: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3 [8086:3a36]
        Latency: 0
        Region 4: I/O ports at a480 [size=32]
00:1d.7 USB Controller [0c03]: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1 [8086:3a3a] (prog-if 20)
        Latency: 0
        Region 0: Memory at f8fff800 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev 90) (prog-if 01)
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Latency: 0
        Bus: primary=00, secondary=07, subordinate=07, sec-latency=32
        I/O behind bridge: 0000e000-0000efff
        Memory behind bridge: fb000000-febfffff
        Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        Capabilities: [50] Subsystem: ASUSTeK Computer Inc. Device [1043:82d4]
00:1f.0 ISA bridge [0601]: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller [8086:3a16]
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Kernel modules: iTCO_wdt
00:1f.2 SATA controller [0106]: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller [8086:3a22] (prog-if 01)
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin B routed to IRQ 31
        Region 0: I/O ports at 9c00 [size=8]
        Region 1: I/O ports at 9880 [size=4]
        Region 2: I/O ports at 9800 [size=8]
        Region 3: I/O ports at 9480 [size=4]
        Region 4: I/O ports at 9400 [size=32]
        Region 5: Memory at f8ffe800 (32-bit, non-prefetchable) [size=2K]
        Capabilities: [80] Message Signalled Interrupts: Mask- 64bit- Queue=0/4 Enable+
                Address: fee0300c  Data: 41b1
        Capabilities: [70] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
        Capabilities: [a8] SATA HBA <?>
        Capabilities: [b0] Vendor Specific Information <?>
        Kernel driver in use: ahci
        Kernel modules: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 82801JI (ICH10 Family) SMBus Controller [8086:3a30]
        Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Interrupt: pin C routed to IRQ 5
        Region 0: Memory at f8fff400 (64-bit, non-prefetchable) [size=256]
        Region 4: I/O ports at 0400 [size=32]
        Kernel modules: i2c-i801
01:00.0 VGA compatible controller [0300]: nVidia Corporation GT215 [GeForce GT 240] [10de:0ca3] (rev a2)
        Subsystem: Giga-byte Technology Device [1458:34e5]
        Latency: 0
        Region 0: Memory at f9000000 (32-bit, non-prefetchable) [size=16M]
        Region 1: Memory at d0000000 (64-bit, prefetchable) [size=256M]
        Region 3: Memory at ce000000 (64-bit, prefetchable) [size=32M]
        Region 5: I/O ports at bc00 [size=128]
        [virtual] Expansion ROM at fab00000 [disabled] [size=512K]
        Capabilities: [60] Power Management version 3
        Capabilities: [68] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
        Capabilities: [78] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
                LnkCap: Port #0, Speed 5GT/s, Width x16, ASPM L0s L1, Latency L0 <512ns, L1 <4us
                        ClockPM+ Suprise- LLActRep- BwNot-
                LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- Retrain- CommClk+
                        ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
        Capabilities: [b4] Vendor Specific Information <?>
        Capabilities: [128] Power Budgeting <?>
        Capabilities: [600] Vendor Specific Information <?>
        Kernel driver in use: nvidia
        Kernel modules: nvidia-current, nvidiafb, nouveau
01:00.1 Audio device [0403]: nVidia Corporation High Definition Audio Controller [10de:0be4] (rev a1)
        Interrupt: pin B routed to IRQ 17
        Region 0: Memory at fabfc000 (32-bit, non-prefetchable) [size=16K]
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
                LnkCap: Port #0, Speed 5GT/s, Width x16, ASPM L0s L1, Latency L0 <512ns, L1 <1us
                LnkCtl: ASPM L0s L1 Enabled; RCB 128 bytes Disabled- Retrain- CommClk-
02:00.0 USB Controller [0c03]: NEC Corporation Device [1033:0194] (rev 04) (prog-if 30)
        Region 0: Memory at facfe000 (64-bit, non-prefetchable) [size=8K]
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
        Capabilities: [70] Message Signalled Interrupts: Mask- 64bit+ Queue=0/3 Enable-
        Capabilities: [90] MSI-X: Enable- Mask- TabSize=8
                Vector table: BAR=0 offset=00001000
                PBA: BAR=0 offset=00001080
        Capabilities: [a0] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Latency L0 <4us, L1 unlimited
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
        Capabilities: [100] Advanced Error Reporting <?>
        Capabilities: [140] Device Serial Number ff-ff-ff-ff-ff-ff-ff-ff
        Capabilities: [150] #18
        Kernel driver in use: xhci_hcd
        Kernel modules: xhci
03:00.0 Ethernet controller [0200]: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller [11ab:4364] (rev 12)
        Subsystem: ASUSTeK Computer Inc. Device [1043:81f8]
        Interrupt: pin A routed to IRQ 30
        Region 0: Memory at fadfc000 (64-bit, non-prefetchable) [size=16K]
        Region 2: I/O ports at c800 [size=256]
        Expansion ROM at fadc0000 [disabled] [size=128K]
        Capabilities: [48] Power Management version 3
                Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
                Status: D0 PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [50] Vital Product Data <?>
        Capabilities: [5c] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable+
                Address: 00000000fee0800c  Data: 41a9
        Capabilities: [e0] Express (v1) Legacy Endpoint, MSI 00
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <256ns, L1 unlimited
        Kernel driver in use: sky2
        Kernel modules: sky2
04:00.0 IDE interface [0101]: Marvell Technology Group Ltd. 88SE6121 SATA II Controller [11ab:6121] (rev b1) (prog-if 8f [Master SecP SecO PriP PriO])
        Subsystem: ASUSTeK Computer Inc. Device [1043:8212]
        Region 0: I/O ports at dc00 [size=8]
        Region 1: I/O ports at d880 [size=4]
        Region 2: I/O ports at d800 [size=8]
        Region 3: I/O ports at d480 [size=4]
        Region 4: I/O ports at d400 [size=16]
        Region 5: Memory at faeffc00 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [48] Power Management version 2
                Flags: PMEClk- DSI- D1+ D2- AuxCurrent=0mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
        Capabilities: [50] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
                Address: 00000000  Data: 0000
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr+ NoSnoop-
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Latency L0 <256ns, L1 unlimited
        Kernel driver in use: pata_marvell
        Kernel modules: pata_marvell, ahci
05:00.0 Multimedia controller [0480]: Philips Semiconductors Device [1131:7160] (rev 02)
        Subsystem: Device [6984:0013]
        Interrupt: pin A routed to IRQ 18
        Region 0: Memory at faf00000 (64-bit, non-prefetchable) [size=1M]
        Capabilities: [40] Message Signalled Interrupts: Mask- 64bit+ Queue=0/5 Enable-
        Capabilities: [80] Vendor Specific Information <?>
        Capabilities: [100] Vendor Specific Information <?>
        Kernel modules: saa716x_tbs-dvb
07:00.0 Network controller [0280]: Tiger Jet Network Inc. Tiger3XX Modem/ISDN interface [e159:0001]
        Subsystem: Device [b119:0001]
        Latency: 64 (250ns min, 32000ns max)
        Region 0: I/O ports at e800 [size=256]
        Region 1: Memory at febff000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [40] Power Management version 2
                Flags: PMEClk- DSI+ D1- D2+ AuxCurrent=55mA PME(D0+,D1-,D2+,D3hot+,D3cold+)
        Kernel driver in use: wctdm
        Kernel modules: wcopenpci, wctdm, hisax, netjet
07:01.0 Multimedia video controller [0400]: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [14f1:8800] (rev 05)
        Subsystem: Hauppauge computer works Inc. Device [0070:9002]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Latency: 64 (5000ns min, 13750ns max), Cache Line Size: 32 bytes
        Interrupt: pin A routed to IRQ 17
        Region 0: Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
        Capabilities: [44] Vital Product Data <?>
        Capabilities: [4c] Power Management version 2
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Kernel driver in use: cx8800
        Kernel modules: cx8800
07:01.2 Multimedia controller [0480]: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [MPEG Port] [14f1:8802] (rev 05)
        Latency: 64 (1500ns min, 22000ns max), Cache Line Size: 32 bytes
        Region 0: Memory at fc000000 (32-bit, non-prefetchable) [size=16M]
        Kernel driver in use: cx88-mpeg driver manager
        Kernel modules: cx8802
07:01.4 Multimedia controller [0480]: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [IR Port] [14f1:8804] (rev 05)
        Latency: 64 (1500ns min, 63750ns max), Cache Line Size: 32 bytes
        Interrupt: pin A routed to IRQ 11
        Region 0: Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
07:02.0 Ethernet controller [0200]: Marvell Technology Group Ltd. 88E8001 Gigabit Ethernet Controller [11ab:4320] (rev 14)
        Subsystem: ASUSTeK Computer Inc. Device [1043:811a]
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Latency: 64 (5750ns min, 7750ns max), Cache Line Size: 32 bytes
        Region 0: Memory at febf8000 (32-bit, non-prefetchable) [size=16K]
        Region 1: I/O ports at e400 [size=256]
        Expansion ROM at febc0000 [disabled] [size=128K]
        Kernel driver in use: skge
        Kernel modules: skge
07:03.0 FireWire (IEEE 1394) [0c00]: Agere Systems FW322/323 [11c1:5811] (rev 70) (prog-if 10)
        Subsystem: ASUSTeK Computer Inc. Device [1043:8294]
        Latency: 64 (3000ns min, 6000ns max), Cache Line Size: 32 bytes
        Interrupt: pin A routed to IRQ 19
        Region 0: Memory at febfe000 (32-bit, non-prefetchable) [size=4K]
        Capabilities: [44] Power Management version 2
                Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
                Status: D0 PME-Enable- DSel=0 DScale=0 PME+
        Kernel driver in use: ohci1394
        Kernel modules: firewire-ohci, ohci1394
stefb
Re: TBS6981 vs. TBS6984 signal quality
Postby cody » Mon Aug 06, 2012 6:42 am
hi Micke,
in the email to support@tbsdtv.com you additionally mentioned that on your TBS6981 card reception works OK on one of the two tuners, but with heavy errors on the other tuner, i.e. similar to what happens with your 6984 card on all tuners. so, that's completely not normal and even leaving aside 6984 for a moment there are has to be some reason to experience such issue with your 6981 card - it could be related to the problem you have with 6984 too. so, my suggestion is to do it step-by-step, i.e. first investigate what causes the problem with one of the tuners on your 6981 card.
so, here are my suggestions what to do/try in order to collect more details with 2 tuners of your 6981 card:
1) run 'szap-s2' without command line switches "-O25 -M5 -C34", i.e. leave the hardware/driver to auto-detect those parameters from the signal : 6981 and 6984 hardware/driver are capable to do that
2) create text file '/etc/modprobe.d/tbsfe.conf' with the entries:
options tbsfe dbm=1
options tbsfe esno=1
and reboot - that will active reporting of the 'signal' and 'SNR' on 'szap-s2' output by the driver respectively in dBm and dB, after do not use '-H' command line switch when run 'szap-s2', because that will prevent proper output of raw dBm and dB values. so, running "./szap-s2 -a 0 -c thor.conf -S1" is enough and for example output:
status 1f | signal 002a | snr 0075 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
means:
* C/N in EsNo dB is 11.7 dB, because '75' in decimal value is 117 and 117 = 10*(EsNo dB)
* dBm is -42, because '2a' in decimal value is 42 and 42 = (-1)*dBm
3) while 'szap-s2' is running, execute:
# dvbsnoop -adapter 0 -s feinfo
and save the output - the point is to check the actually tuned frequency and estimate the frequency offset, because i suspect issue with your LNB, i.e. unstable oscillator, which could cause such issues
4) record raw TS stream and upload it somewhere to check it - again that can be done with 'dvbsnoop' while 'szap-s2' is running and has lock:
# dvbsnoop -adapter 0 -b -s ts -tsraw > file.ts
so, based on the test results of tuner A and B on your 6981 card you collected with the above steps we will proceed. thank you.
Postby micke » Tue Aug 07, 2012 1:32 am
Hi Cody,
Today everything actually worked very well, except when it was heavy rain (no lock).
But that stopped reception on the sagem receiver so I can't complain about that.
I have tested three different transponders on Thor, on both tuners:
(adapter 0 and 1 are TBS6280 which works perfectly).
szap-s2$ ./szap-s2 -a 2 -c thor.conf -S1 TV1
reading channels from file 'thor.conf'
zapping to 2 'TV1':
delivery DVB-S2, modulation QPSK
sat 0, frequency 10934 MHz H, symbolrate 25000000, coderate auto, rolloff 0.35
vpid 0x0200, apid 0x0280, sid 0x057e
using '/dev/dvb/adapter2/frontend0' and '/dev/dvb/adapter2/demux0'
status 1f | signal 0024 | snr 0081 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0024 | snr 0083 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0024 | snr 0084 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
Current parameters:
    Frequency:  1185.171 MHz
    Inversion:  OFF
    Symbol rate:  25.000000 MSym/s
    FEC:
szap-s2$ ./szap-s2 -a 3 -c thor.conf -S1 TV1reading channels from file 'thor.conf'
zapping to 2 'TV1':
using '/dev/dvb/adapter3/frontend0' and '/dev/dvb/adapter3/demux0'
status 1f | signal 0023 | snr 0000 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0023 | snr 0086 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0022 | snr 0085 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0023 | snr 0084 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0023 | snr 0085 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
Current parameters:
    Frequency:  1185.164 MHz
    Inversion:  OFF
    FEC:
szap-s2$ ./szap-s2 -a 2 -c thor.conf -S0 LS
zapping to 4 'LS':
sat 0, frequency 10716 MHz H, symbolrate 24500000, coderate auto, rolloff 0.35
vpid 0x0206, apid 0x02b8, sid 0x0af6
status 1f | signal 0025 | snr 007f | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0025 | snr 0080 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0024 | snr 0082 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0024 | snr 0080 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
Current parameters:
    Frequency:  966.414 MHz
    Inversion:  OFF
    Symbol rate:  24.500000 MSym/s
    FEC:  FEC 7/8
szap-s2$ ./szap-s2 -a 3 -c thor.conf -S0 LS reading channels from file 'thor.conf'
zapping to 4 'LS':
status 1f | signal 0022 | snr 0000 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0022 | snr 0082 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0022 | snr 0080 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0022 | snr 0081 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
Current parameters:
    Frequency:  966.409 MHz
    Inversion:  OFF
    FEC:  FEC 7/8
szap-s2$ ./szap-s2 -a 2 -c thor.conf -S1 DHD
zapping to 5 'DHD':
sat 0, frequency 12015 MHz H, symbolrate 30000000, coderate auto, rolloff 0.35
vpid 0x0201, apid 0x0284, sid 0x1006
status 1f | signal 0023 | snr 0068 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0023 | snr 0069 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0023 | snr 006a | ber 00000000 | unc 00000000 | FE_HAS_LOCK
Current parameters:
    Frequency:  1415.510 MHz
    Inversion:  OFF
    Symbol rate:  30.000000 MSym/s
    FEC:
szap-s2$ ./szap-s2 -a 3 -c thor.conf -S1 DHD
zapping to 5 'DHD':
status 1f | signal 0021 | snr 0067 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0021 | snr 006d | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0022 | snr 0069 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0021 | snr 006b | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0022 | snr 006b | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal 0022 | snr 006a | ber 00000000 | unc 00000000 | FE_HAS_LOCK
Current parameters:
    Frequency:  1415.470 MHz
    Inversion:  OFF
    FEC:
I have not yet captured any .ts streams, but right now the reception is OK when I tested (the reception isn't always bad on the TBS6981, but it is on the TBS6984, but it isn't installed right now so I can't test.
I will do more dumps when have issues again, but is the numbers OK/normal so far?
All numbers worst case:
    1MHz off (1185 instead of 1184MHz).
    -37dBm signal
    10.3dB SNR (worst case)
I have tried other LNA:s with same result, so I don't think the LNA is the cause.
Best regards
Mikael
micke
