Driver is not intended for this platform.
Postby berry » Fri Apr 01, 2011 2:41 am
running Windows 7 64 get this message when loading up drivers
"Driver is not intended for this platform."
if i run the set up for the drivers i get this in device manager
This device cannot start. (Code 10)
berry
Re: Driver is not intended for this platform.
Postby steven » Fri Apr 01, 2011 9:02 am
You can try this
first,delete C:\Windows\System32\drivers\TBS6981.sys
then,delete C:\Windows\inf\oem*.inf ,all oem*.inf files and oem*.PNF files,
Then use (TBS6981setup_win7.exe) the setup file ,and set again
Postby berry » Fri Apr 01, 2011 3:56 pm
Will give this a try later. would the new windows 7 service pack have caused this as i applied it a few days ago?
berry
Postby berry » Sat Apr 02, 2011 1:46 am
Still getting error. This is in the event log
Fault bucket 1836442967, type 5
Event Name: PnPDriverInstallError
Response: Not available
Cab Id: 0
Problem signature:
P1: x64
P2: E0000234
P3: tbs6981.inf
P4: c3c9bb71e7017c2f5c5a4aec4f66fc58608d1ec4
P5: tbsBDA.tbs6981
P6:
P7:
P8:
P9:
P10:
berry
Postby berry » Sat Apr 02, 2011 2:56 am
Ok booted to safe mode and the driver was working went back into normal windows and not its not working. Has no one got any ideas
berry
Postby steven » Sat Apr 02, 2011 11:24 am
Hi berry
did 6981 is ok before you install the new pack?
Postby berry » Sat Apr 02, 2011 4:35 pm
Didn't think so im guessing a faulty card as i have reinstalled 64 and a 32 bit windows 7 and still getting a This device cannot start. (Code 10) message.
berry
Postby berry » Sat Apr 02, 2011 5:29 pm
Has anyone had any issue with the driver been unsigned. If i turn off this setting the computer blue screens
berry
Postby berry » Tue Apr 05, 2011 3:39 pm
Card would not start in friends PC so it seems after all its a faulty card. Friends PC is running two if theses with windows media centre, swapped out one of his card and popped mine in and got the same errors.
berry
Postby steven » Mon Apr 11, 2011 9:39 am
You can contact our support@tbsdtv.com to get a RMA service.
thanks
