1.0.4.9 signal problem
Postby cengizhan » Thu Mar 31, 2011 1:23 am
there are some channels with no signal which worked with 1.0.4.8.
example : turksat 3a, 11064mhz,v,13000
cengizhan
Re: 1.0.4.9 signal problem
Postby steven » Sat Apr 02, 2011 11:39 am
1.0.4.9 is designed to solve sleep problem,if you have not the sleep problem ,you can still use 1.0.4.8.
and for this problem we will check it ,thanks.
Postby Golf520v » Tue Apr 05, 2011 3:14 am
The signal problem not only on Turksat 2a/3a same problem showed up on Hellassat 2 39 E for example 11512 H 30000, 11052 V 30000, 11473 H 2893, not worked with New version 1.0.4.9. When i back up to old version of driver 1.0.4.8 everything working fine
Golf520v
Postby steven » Mon Apr 18, 2011 10:28 am
Golf520v Wrote:The signal problem not only on Turksat 2a/3a same problem showed up on Hellassat 2 39 E for example 11512 H 30000, 11052 V 30000, 11473 H 2893, not worked with New version 1.0.4.9. When i back up to old version of driver 1.0.4.8 everything working fine
Would mind to tell me what's your LNB type,and which player you are using?
Postby Golf520v » Sun Apr 24, 2011 3:20 am
My Lnb is Inverto Quad Flange LNB for four receivers and my DVB Player is DvbDream 1.5e reg. I change output 1 witch going to tbs 6920 from LNB output to 2,3,4. Even when only tbs 6920 is connected to LNB on different output port result was the same no signal. When i back-up to old driver 1.0.4.8 TBS 6920 is working fine with all port on LNB with or without other sat. receiver.
Golf520v
Postby steven » Mon Apr 25, 2011 2:17 pm
would mind to give me a pic about your LNB setting's value with DVBdream,because microsoft BDA driver maybe send some wrong command,so i want to know what's your dvbdream LNB setting,and i will have a test.
Postby Golf520v » Wed Apr 27, 2011 3:18 am
My dvb dream LNB settings is this http://img843.imageshack.us/i/lnbsettings.jpg/ my lnb model is this http://img847.imageshack.us/i/invquadfl500x500.jpg/ i hope i can help with this image to solve the problem with driver 1.0.4.9 regards.
Golf520v
Postby steven » Fri Apr 29, 2011 10:21 am
I have send a new driver to your email sfsio***@yahoo.com ,just check it ,thanks. :)
Postby Golf520v » Sat Apr 30, 2011 12:22 am
steven Wrote:Hi
Thank u very much for that driver you send me its working very well. Great job :)
Golf520v
Postby steven » Thu May 05, 2011 11:23 am
Golf520v Wrote:
steven Wrote:Hi
You are welcome.
