Dual Tuner use with one Cable
Postby sebo » Wed Mar 30, 2011 10:58 pm
Hello my name is Sebo and I`m new here.
I have a Installation of 3 LNBs connected to a switch and can receive 2 Channels with only one Cable on my regular DVB-S Tuner Box. (horizontal & vertical at the same time)
My question: Is it possible to receive 2 Channels with different directions using one Cable at the TBS6981?
And do I need a Dual Tuner Card for this or can I use a Single Tuner Card?
Sebo
sebo
Re: Dual Tuner use with one Cable
Postby steven » Thu Mar 31, 2011 11:28 am
first welcome to here. :D
if you want to receive 2 Channels with only one Cable on my regular DVB-S Tuner Box. (horizontal & vertical at the same time),
Single can not do this.
But dual tuner can ,because dual tuner have two LNB Control,like LNB A use horizontal, and LNB B use vertical.
So 6981 can do what you want.
