TBS-6220 not work on OpenELEC
Postby uni1q » Mon Dec 12, 2011 4:32 pm
Hello!
Sorry for my English.
Help me please! Do not load module saa716x_tbs_dvb for TBS-6220. On the same system TBS-6920 works fine.
# uname -a
Linux openelec 3.1.5 #1 SMP PREEMPT Sat Dec 10 18:15:41 EET 2011 i686 GNU/Linux
# dmesg
[    6.080212] udevd[204]: starting version 175
[    6.653563] tbs6928fe: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
[    6.653572] Disabling lock debugging due to kernel taint
[    6.703215] Registered IR keymap rc-rc6-mce
[    6.703477] input: Media Center Ed. eHome Infrared Remote Transceiver (0bda:0161) as /devices/pci0000:00/0000:00:16.2/usb3/3-3/3-3:1.2/rc/rc0/input5
[    6.703639] rc0: Media Center Ed. eHome Infrared Remote Transceiver (0bda:0161) as /devices/pci0000:00/0000:00:16.2/usb3/3-3/3-3:1.2/rc/rc0
[    6.710233] input: MCE IR Keyboard/Mouse (mceusb) as /devices/virtual/input/input6
[    6.710634] mceusb 3-3:1.2: Registered Generic USB2.0-CRW on usb3:2
[    6.710702] usbcore: registered new interface driver mceusb
[    6.921089] snd_hda_intel 0000:00:01.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    6.921169] snd_hda_intel 0000:00:01.1: irq 44 for MSI/MSI-X
[    6.922213] snd_hda_intel 0000:00:01.1: setting latency timer to 64
[    6.990378] saa716x_tbs_dvb: Unknown symbol i2c_bit_add_bus (err 0)
[    7.060175] HDMI status: Codec=0 Pin=3 Presence_Detect=0 ELD_Valid=0
[    7.063785] input: HD-Audio Generic HDMI/DP as /devices/pci0000:00/0000:00:01.1/sound/card0/input7
# lspci -vvnn
01:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
   Subsystem: Device [6220:0002]
   Interrupt: pin A routed to IRQ 7
   Region 0: Memory at fea00000 (64-bit, non-prefetchable) [size=1M]
      DevCap:   MaxPayload 128 bytes, PhantFunc 0, Latency L0s <256ns, L1 <1us
      DevCtl:   Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
      DevSta:   CorrErr- UncorrErr+ FatalErr- UnsuppReq+ AuxPwr- TransPend-
      LnkCap:   Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <4us, L1 <64us
      LnkCtl:   ASPM Disabled; RCB 128 bytes Disabled- Retrain- CommClk-
      LnkSta:   Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
# modprobe saa716x_tbs_dvb
modprobe: can't load module saa716x_tbs_dvb (tbs/saa716x_tbs-dvb.ko): unknown symbol in module, or unknown parameter
Log.zip
dmesg_log & lspci_log
(16.03 KiB) Downloaded 613 times
uni1q
Re: TBS-6220 not work on OpenELEC
Postby uni1q » Tue Dec 13, 2011 8:08 pm
This problem, I decided. We needed a module "i2c-algo-bit."
But another problem. No driver "tbs62x0fe_driver.o.x86_r3" for the mode DVB-T2.
Where can I download it. Please tell me.
uni1q
Tbsdtv Forum &bull; Post a reply
Postby Meerboape » Fri Mar 16, 2012 8:44 pm
Buy Online Xanax - Click Here!
Human psychology has already accepted the co-existence of excellent and evil from the the second Adam and Eve ate the apple of expertise. You can find happiness with sorrow, pleasure with pain, truth with lie, beauty with ugliness etc. You've seen the happy moments in your life plus the moments of sorrow. Sometimes the memory and nervous about the not so good time continues haunting you and you are incredibly much overwhelmed that you simply forget to smile. Are you currently depressed and full of anxiety at all times? Have you been in times which is often referred to as a disorder?
Never underestimate your depression and anxiety, they can be real world enemies road directions of every never underestimate your enemies. Let me tell you the signs and symptoms of panic attack to be able to compare and understand your condition. There are specific physical symptoms of anxiety disorder, e.g. rapid or irregular heartbeat, nausea like gnawing feeling, nausea, "butterflies within the stomach" diarrhea, irritated bowel syndrome, sweating, or feeling cold and clammy headaches, lightheadedness or dizziness, body tension or aches, fatigue or shortness of breath shaking, trembling or twitching difficulty sleeping or staying asleep, hot flashes or chills, chest pain, rubbery legs, tingling in fingers or toes. Simultaneously there are a few emotional symptoms also just like a general a feeling of apprehension and dread, nervousness, jumpiness, irritation, fearfulness or terror, isolation from others, feeling incredibly self-conscious and insecure, and fear you're dying or going wild strong desire to escape.
Meerboape
