How can I install the IR-Receiver of my TBS6928
Postby seedvb » Sat Dec 10, 2011 6:42 am
Hello
I have the TBS6928 and I it works fine.
But the IR-Receiver don' t work. I habe tested many rouls in /etc/udev/roules.d/..., but I don't know, how the syntax is for the IR-Receiver.
Or witch is the fault?
Works the IR-Receiver in Linux?
I have a Ubuntu 11.10 system (EasyVDR 0.9.50, Kernel 3.x)
Can anyone help me for make it working?
Greetings
seedvb
seedvb
Re: How can I install the IR-Receiver of my TBS6928
Postby SergioDanielG » Sat Dec 10, 2011 9:05 am
Can you run
cat /proc/bus/input/devices
and see if you have something as
I: Bus=0001 Vendor=6920 Product=8888 Version=0001
N: Name="cx23885 IR (TurboSight TBS 6920)"
P: Phys=pci-0000:03:00.0/ir0
S: Sysfs=/devices/pci0000:00/0000:00:06.0/0000:03:00.0/rc/rc1/input9
U: Uniq=
H: Handlers=kbd event9
B: PROP=0
B: EV=100013
B: KEY=3000000100c0000 34301100000000 0 100000 408000000800 8e168000000000 ffc
B: MSC=10
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="MCE IR Keyboard/Mouse (cx23885)"
P: Phys=/input0
S: Sysfs=/devices/virtual/input/input10
U: Uniq=
H: Handlers=sysrq kbd mouse3 event10
B: PROP=0
B: EV=100017
B: KEY=30000 7 ff87207ac14057ff febeffdfffefffff fffffffffffffffe
B: REL=3
B: MSC=10
If yes, there is the remote; if not... I don't know...
Best regards
SergioDanielG
Postby seedvb » Sat Dec 10, 2011 7:04 pm
Hello
I have called this command, but nothing is there like TBS or IR or something...
easyvdr@easyVDR:~$ cat /proc/bus/input/devices
I: Bus=0019 Vendor=0000 Product=0001 Version=0000
N: Name="Power Button"
P: Phys=PNP0C0C/button/input0
S: Sysfs=/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
U: Uniq=
H: Handlers=kbd event0
B: PROP=0
B: EV=3
B: KEY=100000 0 0 0
P: Phys=LNXPWRBN/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
U: Uniq=
H: Handlers=kbd event1
B: PROP=0
B: EV=3
B: KEY=100000 0 0 0
I: Bus=0003 Vendor=0518 Product=0001 Version=0110
N: Name="Composite USB PS2 Converter USB to PS2 Adaptor  v1.12"
P: Phys=usb-0000:00:02.0-1/input0
S: Sysfs=/devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/input/input2
U: Uniq=
H: Handlers=sysrq kbd event2
B: PROP=0
B: EV=120013
B: KEY=10000 7 ff980000 7ff febeffdf ffefffff ffffffff fffffffe
B: MSC=10
B: LED=7
P: Phys=usb-0000:00:02.0-1/input1
S: Sysfs=/devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.1/input/input3
U: Uniq=
H: Handlers=kbd mouse0 event3
B: PROP=0
B: EV=1f
B: KEY=4c37fff 72ff32d bf544446 0 0 70001 20c10 b17c000 267bfa d951dfed 9e1680 4400 0 10000002
B: REL=143
B: ABS=1 0
B: MSC=10
I: Bus=0003 Vendor=046d Product=c016 Version=0110
N: Name="Logitech Optical USB Mouse"
P: Phys=usb-0000:00:04.0-2/input0
S: Sysfs=/devices/pci0000:00/0000:00:04.0/usb4/4-2/4-2:1.0/input/input4
U: Uniq=
H: Handlers=mouse1 event4
B: PROP=0
B: EV=17
B: KEY=70000 0 0 0 0 0 0 0 0
B: REL=103
B: MSC=10
I: Bus=0019 Vendor=0000 Product=0006 Version=0000
N: Name="Video Bus"
P: Phys=LNXVIDEO/video/input0
S: Sysfs=/devices/LNXSYSTM:00/device:00/PNP0A03:00/device:12/LNXVIDEO:00/input/input5
U: Uniq=
H: Handlers=kbd event5
B: PROP=0
B: EV=3
B: KEY=3e000b 0 0 0 0 0 0 0
easyvdr@easyVDR:~$
Can anione help me?
Best regards
seedvb
seedvb
Postby seedvb » Thu Dec 15, 2011 1:44 pm
Hello
The IR-Receiver do not working with the Linux Driver?
Can anyone help me?
Greetings
seedvb
seedvb
Postby j03 » Fri Dec 30, 2011 8:08 am
hi,
can you run:
evtest /dev/input/event5
...and press some buttons on the remote
i guess that's your input device, and mine is broken, because nothing happens :(
root@dvb:~# evtest /dev/input/event5
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x0 product 0x6 version 0x0
Input device name: "Video Bus"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 224 (KEY_BRIGHTNESSDOWN)
    Event code 225 (KEY_BRIGHTNESSUP)
    Event code 227 (KEY_SWITCHVIDEOMODE)
    Event code 241 (KEY_VIDEO_NEXT)
    Event code 242 (KEY_VIDEO_PREV)
    Event code 243 (KEY_BRIGHTNESS_CYCLE)
    Event code 244 (KEY_BRIGHTNESS_ZERO)
    Event code 245 (KEY_DISPLAY_OFF)
Testing ... (interrupt to exit)
j03
