Pre purchase advice. System requirements.
Postby Willhonor » Wed Mar 23, 2011 7:36 am
I am considering buying one (maybe two) 6981 cards to use with an AMD Zacate system (ASUS E35M1-M PRO). Will this card work with such a low power processor. The requirements shown on your website seem to indicate that a 3ghz processor is required. Is that still the case if hardware graphics acceleration is available?
Regards,
Will.
Willhonor
Re: Pre purchase advice. System requirements.
Postby steven » Wed Mar 23, 2011 9:53 am
HI Willhonor
Sorry for the inconvenience,about the cpu requirements if you are Dualcore CPU,there is no matter with it ,thanks. :)
