Device not recognized
Postby rootman » Fri Mar 18, 2011 8:08 pm
driver is not loaded, I think the device ID isn't correct
Bus 001 Device 015: ID 734c:5980
lsusb
Bus 005 Device 002: ID 0a5c:2110 Broadcom Corp. Bluetooth Controller
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 014: ID 0951:1643 Kingston Technology
Bus 001 Device 008: ID 04b3:301b IBM Corp. SK-8815 Keyboard
Bus 001 Device 007: ID 04b3:301a IBM Corp.
Bus 001 Device 006: ID 04b3:310c IBM Corp. Wheel Mouse
Bus 001 Device 004: ID 04b3:4485 IBM Corp. Serial Converter
Bus 001 Device 002: ID 05e3:0722 Genesys Logic, Inc.
dmesg
[ 2058.362598] usb 1-5: USB disconnect, address 13
[ 2060.072553] usb 1-5: new high speed USB device using ehci_hcd and address 15
[ 2060.220594] usb 1-5: configuration #1 chosen from 1 choice
Please Help me
I bought the Q Box CI
rootman
Re: Device not recognized
Postby rootman » Fri Mar 18, 2011 9:29 pm
I solved it myself
I bought the device by bettershopping.eu
http://www.bettershopping.eu/de_AT/shop/PC_Hardware/TV_Karten_Boxen/DVB-S_Satellit/ART01091_TBS_USB_DVB-S2_Q-BOX_II_CI_5980.html
and in there download section there where the drivers and firmware files I was looking for
http://uploads.bettershopping.eu/Software%2008.03.2011.rar
if I do lsusb still no output
lsusb
Bus 001 Device 010: ID 734c:5980
Bus 001 Device 003: ID 05e3:0722 Genesys Logic, Inc.
Bus 001 Device 002: ID 0951:1643 Kingston Technology
but in the dmesg
[ 1012.433287] dvb-usb: TBS Qbox DVB-S2 CI USB2.0 successfully deinitialized and disconnected.
[ 1016.960049] usb 1-5: new high speed USB device using ehci_hcd and address 12
[ 1017.110993] usb 1-5: configuration #1 chosen from 1 choice
[ 1017.111269] dvb-usb: found a 'TBS Qbox DVB-S2 CI USB2.0' in cold state, will try to load a firmware
[ 1017.111278] usb 1-5: firmware: requesting dvb-usb-tbsqbox-id5980.fw
[ 1017.114649] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5980.fw'
[ 1017.114658] usb 1-5: firmware: requesting dvb-usb-tbsqbox-id5980.fw
[ 1017.125510] tbsqbox2ci: start downloading TBSQBOX2CI firmware
[ 1017.250065] dvb-usb: found a 'TBS Qbox DVB-S2 CI USB2.0' in warm state.
[ 1017.250150] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1017.250642] DVB: registering new adapter (TBS Qbox DVB-S2 CI USB2.0)
[ 1017.475747] dvb-usb: MAC address: ff:ff:ff:ff:ff:ff
[ 1017.475750]
[ 1017.625717] tbsqbox2ci: Attached stv0903!
[ 1017.625721]
[ 1017.626158] tbsqbox2ci: CI initialized.
[ 1017.626165] DVB: registering adapter 0 frontend 0 (STV090x Multistandard)...
[ 1017.626398] stb6100_attach: Attaching STB6100
[ 1017.626813] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-5/input/input16
[ 1017.626887] dvb-usb: schedule remote query interval to 150 msecs.
[ 1017.626893] dvb-usb: TBS Qbox DVB-S2 CI USB2.0 successfully initialized and connected.
so I think that solved my problem 8-)
rootman
Postby steven » Sun Mar 20, 2011 8:45 am
Thanks for sharing your method. :D
