Two tuner cards in one pc
Postby Gemelon » Thu May 27, 2010 1:51 am
Hi, I have tried to instal two tuner cards in one PC but then the Computer do no more boot. Why is it not possible to do that?
Gemelon
Re: Two tuner cards in one pc
Postby cody » Thu May 27, 2010 9:20 am
Gemelon Wrote:Hi, I have tried to instal two tuner cards in one PC but then the Computer do no more boot. Why is it not possible to do that?
hi, we have a customer that is using 6 TBS 6980 cards in the same computer without any troubles. also, very common setup is two TBS 6980 cards in the same computer, because DVBLogic TVSource software that is very popular among our customers provides exactly 4 virtual DVB adapters and two TBS 6980 have 4 physical DVB adapters.
so, it should be something wrong with your motherboard - maybe it's good idea to try using different PCI-Express slots or update your motherboard's BIOS.
Postby Gemelon » Mon May 31, 2010 12:56 am
Ok, you're right. I update the BIOS and I tried it once more and voilà it work's. Thank you. My motherboard is an Gigabyte P55A-UD3 whith an i5-750 Prozessor.
Gemelon
Postby cody » Mon May 31, 2010 9:18 am
Gemelon Wrote:Ok, you're right. I update the BIOS and I tried it once more and voilà it work's. Thank you. My motherboard is an Gigabyte P55A-UD3 whith an i5-750 Prozessor.
thanks for sharing this information, it probably will help other users too.
