TBS6928 PCIe DVB-S2 Card Don't work
Postby rvwing » Wed Dec 07, 2011 3:49 am
Hello for your information
I have already Technotrend DVB S2-3200 card and is working perfect.
So, I remove this card then I install the TBS6928 PCIe DVB-S2 Card.
I install the DBA driver TBSViewer TBS-MCECITool
The driver is installed working normal.
I install my CI card the RED LED light up on the board...
I select my DiSEgC in my case Astra 23.5E DiSEgC B/A (Duo LNB)
Then i make a scan nothing happened. No signal nothing. I try scan after scan I try all possibilities bit I don’t get a signal from the satellite…
Some body that have a advice?
Rob
rvwing
Re: TBS6928 PCIe DVB-S2 Card Don't work
Postby smile » Tue Dec 13, 2011 11:34 am
Hi rvwing
Sorry for delay reply,I just have a test with the TBS6928 own scan tool(TBS6928-Blind Scan),it is work well. what is the scan tool you used and Are you using the lastest driver version.
thanks
smile
