Can't install driver in Win 7
Postby pt95cca » Wed Mar 09, 2011 7:41 pm
I have a Windows 7 Media Center PC in which I have installed two TBS cards, one 6980 dual tuner PCI-E card, and one 8920. After first installation both cards were installed correctly with the latest drivers, but after my first reboot after that, the 8920 card was lost, and now I can't get it back again.
It shows up as an uninstalled "Video controller" in the Device Manager, but when I try to "Update driver" it starts searching on Windows update and installs a completely bogus driver. If I try to point it manually to the TBS driver folder, it just says that there is no suitable driver found in that directory.
I have tried uninstalling the device, uninstalling and reinstalling the drivers, rebooting, removing and reinserting the card into the PC, well just about everything. But I still can't get it to recognize the card again. I know it should be possible as I succeeded once before the initial reboot.
Any hints?
Christopher
pt95cca
Re: Can't install driver in Win 7
Postby pt95cca » Wed Mar 09, 2011 7:52 pm
Just browsed the homepage and realized that this card might not be supported under Windows 7? That could of course be one reason - but strange in that case that I could install it once.
pt95cca
Postby pt95cca » Wed Mar 09, 2011 8:02 pm
Never mind. This is really annoying. You spend hours of time trying to install it, then post a question here, and then find the solution a few minutes afterwards.
If anyone else runs into the same problem, here's what I did:
- Installed the driver
- Right-clicked the device in device manager, selected "Update driver"
- Choose the second option "driver already installed on this computer"
- Once again second option "let me choose from a list"
- Find TBS in the list and select the DVBS driver
- Repeat the above for the next unrecognized driver as well (TS Capture something)
pt95cca
Postby steven » Wed Mar 09, 2011 9:31 pm
Thanks for sharing your method. :)
