QboxII whis Dreambox Kernel 2.6.18 posible?
Postby troll » Tue Mar 08, 2011 11:51 pm
is posible to code driver for dreambox mipsel kernel 2.6.18?
I have two dreamboxes whis usb and the gui can 4 tuner .
http://www.dream-multimedia-tv.de/dm-800-hd-se
The dreamcommunity is very big and many users search for second tuner , i the box work i can post this an a big forum.
regard
troll
troll
Re: QboxII whis Dreambox Kernel 2.6.18 posible?
Postby steven » Thu Mar 17, 2011 10:22 am
We have not tested it,you can try it by yourself, :D
Postby marcelru » Sun May 15, 2011 10:38 pm
Hi troll,
I only joined this forum yesterday, so maybe you already found the solution.
Recently, I successfully built the kernel modules for a TBS5980 (same box as you have, with a CAM slot, if I'm not mistaken) for kernel 2.6.18 on an x86_64 machine. I also made some other DVB kernel modules for the 2.6.18 kernel, for the ARM platform and x86_64. Both sets of modules worked as they should. The entire operation involved backporting the DVBAPI 5.0 to the 2.6.18 kernel, which turned out to be relatively simple.
HTH,
marcelr
marcelru
Postby marcelru » Thu Jul 14, 2011 4:59 pm
Hi all,
Yesterday I successfully compiled the kernel modules for a tbs5980 (QBox CI) for kernel 2.6.18 (for ARM architecture, i.e., my TV to be more specific). Will try the QboxII later today. If you're interested, send me a PM and I'll try and upload the code somewhere (It's a full fledged linux kernel tree, typically 70MB or so ..). Haven't got a toolchain for the dreambox at hand, so I can't test that for you.
grtz,
marcelr
marcelru
Postby jordyto » Wed Aug 24, 2011 8:38 pm
I'm especially interested in runing QBox 3 on ARM based Linux platform, so my questions are related to the possible drivers I can use.
As I only see binary drivers (x86/amd_64) and no sources in all TBS driver packages available for download is there any chance we can get ARM builds or sources.
Thank you!
jordyto
Postby marcelru » Thu Aug 25, 2011 4:06 am
As I only see binary drivers (x86/amd_64) and no sources in all TBS driver packages available for download ...
You may want to checkout the linux-tbs-drivers_110818.rar package, available from the downloads page. It holds the code to build the drivers for linux, DVB-API version 5.0 and higher. To build for older kernels (DVB-API < 5.0), the kernel tree needs some serious patching.
HTH,
marcelru
marcelru
