GA-E350N-USB3 Compatiblity
Postby TwoGunTurtle » Sun Mar 06, 2011 10:38 pm
I am building a new HTPC based on the new Hudson-M1 from AMD. The motherboard I have bought is a Gigabyte GA-E350N-USB3. I bought a 6981 for this PC as I was pleased with the first one I bought for another PC.
I built the PC and got Windows 7 on no problems. The next day the tv card arrived, I put it in , but the machine will not POST. No POST beeps - nothing. I tried my other 6981 and got the same problem.
When I took the card out out it boots again without problem.
I tired another power supply and I am giving the 6981's full power with the supplied adapter. Still the problem persists.
I sent the motherboard back to the supplier thinking it was faulty, but they have tested it and found it to be OK, they have charged me for testing and have sent it back to me.
Is there any reason why this should not work, could there be a compatibility issue? There motherboard has 1 PCIE v2.0 x16 running at x4.
http://www.gigabyte.com/products/product-page.aspx?pid=3681#ov
From what I understand from reading in this forum the 6981 should work in any PCIE slot v1.0/2.0 and x1, x4, x8, x16.
Any advice would be appreciated. Many thanks,
Rod
TwoGunTurtle
Re: GA-E350N-USB3 Compatiblity
Postby steven » Wed Mar 09, 2011 10:34 am
Hi sorry about this,we are buying the Gigabyte GA-E350N-USB3 motherboard for test.
We will give you a answer as soon as possible! :)
Postby TwoGunTurtle » Thu Mar 10, 2011 9:52 pm
Thank you Steven! That really is excellent service.
I look forward to your findings.
Rod
TwoGunTurtle
Postby steven » Fri Mar 11, 2011 10:16 am
Gigabyte GA-E350N-USB3 motherboard has arrived,and we have tested it,the problem you met had occurred here too.
We checked all card which have CX23885 chip not only 6981 that have the problem too,so we think it maybe the chip's compatible problem.
We are contacting conexant to solve the problem,and we are try our best to figure it out.
Just wait for our good news
thanks :D
Postby steven » Thu Mar 24, 2011 11:09 am
about the Gigabyte motherboard compatible problem has new progress,Gigabyte's FAE is going to update BIOS to solve the problem,just wait the new BIOS.
BR
steven :D
Postby TwoGunTurtle » Thu Mar 24, 2011 10:17 pm
Great, thank you for the update Steven!
You have great customer service :D
TwoGunTurtle
Postby steven » Wed Apr 06, 2011 5:40 pm
GIga have updated the BIOS,and i have send a email to you,just check it.
if you have not received it
here is the URL
http://hotfile.com/dl/113515105/ad0c0a7/E350NB3.rar.html
wait for your test report
:D
Postby ms1964 » Sat Apr 09, 2011 6:06 am
impressive support you offer!
I am thinking about buying this card too, and i would like to use it on a "ASUS E35M1-I Deluxe" motherboard.
Does the problem with the gigabyte mobo also apply to the ASUS board?
I was just thinking, because it uses the same CPU and chipset and I dont want to run into the same problem.
Thanks for you help.
Cheers,
MS
ms1964
Postby steven » Sat Apr 09, 2011 6:34 pm
ms1964 Wrote:Hi,
Cheers,
MS
Hi ms1964
ASUS E35M1-I Deluxe is AMD Hudson M1 chipset,and i think it will be ok.
because all the problem motherboard which is the intel chipset ,and intel chipset is not compatible with 1.0a PCI-E,but it can resolved by update the BIOS,like gigabyte.
Postby ms1964 » Mon Apr 11, 2011 3:03 pm
Hi Steven,
thanks for the clarification, I was obviously wrong regarding the chipset.
So I think I'll go for the TBS-6981.
Cheers,
MS
ms1964
