searching channels Intelsat 11-43 º
Postby felipesms » Sat Mar 05, 2011 8:22 am
Hello good evening.
the chip is successfully installed.
And I need a step by step in order to get the satellite channels
help me
I cannot find any channels
Example Intelsat 11 - 43.1 º
felipesms
Re: searching channels Intelsat 11-43 º
Postby felipesms » Mon Mar 07, 2011 12:59 am
find sat
$ scan-s2 -a 1 ./dvb-s/3170
file 3170
S1 10722000 H 30000000 AUTO
S1 10722000 V 30000000 AUTO
S1 10802000 H 28000000 AUTO
S1 10802000 V 28000000 AUTO
S1 10882000 H 28000000 AUTO
S1 10882000 V 28000000 AUTO
S1 10970000 H 29000000 AUTO
S1 10970000 V 28000000 AUTO
S1 11050000 H 29000000 AUTO
S1 11050000 V 29000000 AUTO
S1 11130000 H 28000000 AUTO
S1 11130000 V 28000000 AUTO
S1 11222000 H 30000000 AUTO
S1 11222000 V 30000000 AUTO
S1 11302000 H 30000000 AUTO
S1 11302000 V 30000000 AUTO
S1 11382000 H 30000000 AUTO
S1 11382000 V 30000000 AUTO
root@felipe-pc:/home/felipe/Área de Trabalho# scan-s2 -a 1 ./dvb-s/3170
API major 5, minor 1
ERROR: Cannot open rotor configuration file 'rotor.conf'.
scanning ./dvb-s/3170
using '/dev/dvb/adapter1/frontend0' and '/dev/dvb/adapter1/demux0'
initial transponder DVB-S 10722000 H 30000000 AUTO AUTO AUTO
initial transponder DVB-S 10722000 V 30000000 AUTO AUTO AUTO
initial transponder DVB-S 10802000 H 28000000 AUTO AUTO AUTO
initial transponder DVB-S 10802000 V 28000000 AUTO AUTO AUTO
initial transponder DVB-S 10882000 H 28000000 AUTO AUTO AUTO
initial transponder DVB-S 10882000 V 28000000 AUTO AUTO AUTO
initial transponder DVB-S 10970000 H 29000000 AUTO AUTO AUTO
initial transponder DVB-S 10970000 V 28000000 AUTO AUTO AUTO
initial transponder DVB-S 11050000 H 29000000 AUTO AUTO AUTO
initial transponder DVB-S 11050000 V 29000000 AUTO AUTO AUTO
initial transponder DVB-S 11130000 H 28000000 AUTO AUTO AUTO
initial transponder DVB-S 11130000 V 28000000 AUTO AUTO AUTO
initial transponder DVB-S 11222000 H 30000000 AUTO AUTO AUTO
initial transponder DVB-S 11222000 V 30000000 AUTO AUTO AUTO
initial transponder DVB-S 11302000 H 30000000 AUTO AUTO AUTO
initial transponder DVB-S 11302000 V 30000000 AUTO AUTO AUTO
initial transponder DVB-S 11382000 H 30000000 AUTO AUTO AUTO
initial transponder DVB-S 11382000 V 30000000 AUTO AUTO AUTO
>>> tune to: 10722:hS0:S0.0W:30000:
DVB-S IF freq is 972000
WARNING: >>> tuning failed!!!
>>> tune to: 10722:hS0:S0.0W:30000: (tuning failed)
>>> tune to: 10722:vS0:S0.0W:30000:
^CERROR: interrupted by SIGINT, dumping partial result...
dumping lists (0 services)
Done.
$ felipe@felipe-pc:~$ dmesg
[ 4310.687759] DVB: adapter 1 frontend 0 frequency 9746282 out of range (950000..2150000)
[ 4311.758740] DVB: adapter 1 frontend 0 frequency 9746282 out of range (950000..2150000)
[ 4312.827560] DVB: adapter 1 frontend 0 frequency 9746282 out of range (950000..2150000)
[ 4313.898753] DVB: adapter 1 frontend 0 frequency 9746282 out of range (950000..2150000)
[ 4314.975668] DVB: adapter 1 frontend 0 frequency 9746282 out of range (950000..2150000)
[ 4316.054967] DVB: adapter 1 frontend 0 frequency 9746282 out of range (950000..2150000)
[ 4317.126317] DVB: adapter 1 frontend 0 frequency 9746282 out of range (950000..2150000)
[ 4318.203424] DVB: adapter 1 frontend 0 frequency 9746282 out of range (950000..2150000)
[ 4319.270752] DVB: adapter 1 frontend 0 frequency 9746264 out of range (950000..2150000)
[ 4320.358760] DVB: adapter 1 frontend 0 frequency 9746264 out of range (950000..2150000)
[ 4321.430539] DVB: adapter 1 frontend 0 frequency 9746264 out of range (950000..2150000)
[ 4559.006795] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4560.087995] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4561.158557] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4562.239343] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4563.323940] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4564.399396] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4565.486747] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4566.563668] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4567.642103] DVB: adapter 1 frontend 0 frequency 6014000 out of range (950000..2150000)
[ 4568.714790] DVB: adapter 1 frontend 0 frequency 6014000 out of range (950000..2150000)
[ 4569.786337] DVB: adapter 1 frontend 0 frequency 6014000 out of range (950000..2150000)
[ 4570.874599] DVB: adapter 1 frontend 0 frequency 6014000 out of range (950000..2150000)
[ 4658.014752] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4659.099033] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4660.170747] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4661.246764] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4662.322838] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4663.403940] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4664.487935] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4665.562556] DVB: adapter 1 frontend 0 frequency 6032000 out of range (950000..2150000)
[ 4666.650846] DVB: adapter 1 frontend 0 frequency 6014000 out of range (950000..2150000)
[ 4667.727964] DVB: adapter 1 frontend 0 frequency 6014000 out of range (950000..2150000)
[ 4668.802818] DVB: adapter 1 frontend 0 frequency 6014000 out of range (950000..2150000)
[ 4669.878537] DVB: adapter 1 frontend 0 frequency 6014000 out of range (950000..2150000)
[ 4670.950543] DVB: adapter 1 frontend 0 frequency 6007000 out of range (950000..2150000)
[ 4672.022742] DVB: adapter 1 frontend 0 frequency 6007000 out of range (950000..2150000)
[ 4673.094399] DVB: adapter 1 frontend 0 frequency 6007000 out of range (950000..2150000)
[ 4674.167857] DVB: adapter 1 frontend 0 frequency 6007000 out of range (950000..2150000)
[ 4675.243031] DVB: adapter 1 frontend 0 frequency 5983000 out of range (950000..2150000)
[ 4676.310756] DVB: adapter 1 frontend 0 frequency 5983000 out of range (950000..2150000)
[ 4677.387949] DVB: adapter 1 frontend 0 frequency 5983000 out of range (950000..2150000)
[ 4709.999122] tbs6981fe: modulation 6 is not supported
[ 4713.070901] tbs6981fe: modulation 6 is not supported
[ 4716.147154] tbs6981fe: modulation 6 is not supported
[ 4719.226879] tbs6981fe: modulation 6 is not supported
[ 4722.311375] tbs6981fe: modulation 6 is not supported
[ 4725.387100] tbs6981fe: modulation 6 is not supported
[ 4728.471527] tbs6981fe: modulation 6 is not supported
[ 4731.551974] tbs6981fe: modulation 6 is not supported
[ 4734.630555] tbs6981fe: modulation 6 is not supported
[ 4737.712050] tbs6981fe: modulation 6 is not supported
[ 4740.779103] tbs6981fe: modulation 6 is not supported
[ 4743.855758] tbs6981fe: modulation 6 is not supported
[ 4746.931261] tbs6981fe: modulation 6 is not supported
[ 4750.010551] tbs6981fe: modulation 6 is not supported
[ 4753.087521] tbs6981fe: modulation 6 is not supported
[ 4756.202320] tbs6981fe: modulation 6 is not supported
[ 4759.299375] tbs6981fe: modulation 6 is not supported
[ 4762.378653] tbs6981fe: modulation 6 is not supported
[ 4765.459353] tbs6981fe: modulation 6 is not supported
[ 4768.539961] tbs6981fe: modulation 6 is not supported
[ 4771.619590] tbs6981fe: modulation 6 is not supported
[ 4774.698650] tbs6981fe: modulation 6 is not supported
[ 4777.795969] tbs6981fe: modulation 6 is not supported
[ 4780.879084] tbs6981fe: modulation 6 is not supported
[ 4783.963929] tbs6981fe: modulation 6 is not supported
[ 4787.051394] tbs6981fe: modulation 6 is not supported
[ 4790.131970] tbs6981fe: modulation 6 is not supported
[ 4793.210746] tbs6981fe: modulation 6 is not supported
[ 4796.291921] tbs6981fe: modulation 6 is not supported
[ 4799.371103] tbs6981fe: modulation 6 is not supported
[ 4802.443099] tbs6981fe: modulation 6 is not supported
[ 4805.519098] tbs6981fe: modulation 6 is not supported
[ 4808.614599] tbs6981fe: modulation 6 is not supported
[ 4811.691966] tbs6981fe: modulation 6 is not supported
[ 4814.771083] tbs6981fe: modulation 6 is not supported
[ 4817.851997] tbs6981fe: modulation 6 is not supported
[ 4820.930769] tbs6981fe: modulation 6 is not supported
[ 4824.011094] tbs6981fe: modulation 6 is not supported
[ 4827.087092] tbs6981fe: modulation 6 is not supported
[ 4830.163114] tbs6981fe: modulation 6 is not supported
[ 4833.235622] tbs6981fe: modulation 6 is not supported
[ 4836.314343] tbs6981fe: modulation 6 is not supported
[ 4839.411587] tbs6981fe: modulation 6 is not supported
[ 4842.487844] tbs6981fe: modulation 6 is not supported
[ 4845.566544] tbs6981fe: modulation 6 is not supported
[ 4848.642631] tbs6981fe: modulation 6 is not supported
[ 4851.719097] tbs6981fe: modulation 6 is not supported
[ 4854.795390] tbs6981fe: modulation 6 is not supported
[ 4857.871390] tbs6981fe: modulation 6 is not supported
[ 4860.963647] tbs6981fe: modulation 6 is not supported
[ 4864.042606] tbs6981fe: modulation 6 is not supported
[ 4867.123991] tbs6981fe: modulation 6 is not supported
[ 4870.210455] tbs6981fe: modulation 6 is not supported
[ 4873.291961] tbs6981fe: modulation 6 is not supported
[ 4876.362877] tbs6981fe: modulation 6 is not supported
[ 4879.438399] tbs6981fe: modulation 6 is not supported
[ 4882.514329] tbs6981fe: modulation 6 is not supported
[ 4885.610759] tbs6981fe: modulation 6 is not supported
[ 4888.706888] tbs6981fe: modulation 6 is not supported
[ 4891.782763] tbs6981fe: modulation 6 is not supported
[ 4894.855110] tbs6981fe: modulation 6 is not supported
[ 4897.930623] tbs6981fe: modulation 6 is not supported
[ 4901.002550] tbs6981fe: modulation 6 is not supported
[ 4904.079379] tbs6981fe: modulation 6 is not supported
[ 4907.154886] tbs6981fe: modulation 6 is not supported
[ 4910.231866] tbs6981fe: modulation 6 is not supported
[ 4913.343983] tbs6981fe: modulation 6 is not supported
[ 4916.423116] tbs6981fe: modulation 6 is not supported
[ 4919.498341] tbs6981fe: modulation 6 is not supported
[ 4922.586763] tbs6981fe: modulation 6 is not supported
[ 4925.667010] tbs6981fe: modulation 6 is not supported
[ 4928.751989] tbs6981fe: modulation 6 is not supported
[ 4986.430555] tbs6981fe: modulation 6 is not supported
[ 4989.523094] tbs6981fe: modulation 6 is not supported
[ 4992.598771] tbs6981fe: modulation 6 is not supported
[ 4995.675185] tbs6981fe: modulation 6 is not supported
[ 4998.751790] tbs6981fe: modulation 6 is not supported
[ 5001.828096] tbs6981fe: modulation 6 is not supported
[ 5004.914835] tbs6981fe: modulation 6 is not supported
[ 5008.014766] tbs6981fe: modulation 6 is not supported
[ 5011.091150] tbs6981fe: modulation 6 is not supported
[ 5014.167876] tbs6981fe: modulation 6 is not supported
[ 5017.246748] tbs6981fe: modulation 6 is not supported
[ 5020.327753] tbs6981fe: modulation 6 is not supported
[ 5023.399587] tbs6981fe: modulation 6 is not supported
[ 5026.474949] tbs6981fe: modulation 6 is not supported
[ 5029.547102] tbs6981fe: modulation 6 is not supported
[ 5032.638906] tbs6981fe: modulation 6 is not supported
[ 5035.714541] tbs6981fe: modulation 6 is not supported
[ 5038.800044] tbs6981fe: modulation 6 is not supported
[ 5041.879097] tbs6981fe: modulation 6 is not supported
[ 5044.971089] tbs6981fe: modulation 6 is not supported
[ 5048.046559] tbs6981fe: modulation 6 is not supported
[ 5051.123573] tbs6981fe: modulation 6 is not supported
[ 5054.199485] tbs6981fe: modulation 6 is not supported
[ 5057.278529] tbs6981fe: modulation 6 is not supported
[ 5060.363964] tbs6981fe: modulation 6 is not supported
[ 5063.451908] tbs6981fe: modulation 6 is not supported
[ 5066.530743] tbs6981fe: modulation 6 is not supported
[ 5069.602755] tbs6981fe: modulation 6 is not supported
[ 5072.682774] tbs6981fe: modulation 6 is not supported
[ 5075.762838] tbs6981fe: modulation 6 is not supported
[ 5078.843874] tbs6981fe: modulation 6 is not supported
[ 5081.922900] tbs6981fe: modulation 6 is not supported
[ 5084.998530] tbs6981fe: modulation 6 is not supported
[ 5088.083148] tbs6981fe: modulation 6 is not supported
[ 5091.158766] tbs6981fe: modulation 6 is not supported
[ 5094.235096] tbs6981fe: modulation 6 is not supported
felipesms
