ERROR FE_SET_VOLTAGE: Operation not permitted
Postby nszerver » Thu Jun 19, 2025 5:52 am
Installed and reboot working log:
Hi, I managed to get it working but a little interesting thing is this not a problem for the system?
Another thing is that I use multiswitch, channels work but I don't know if this is a problem or not.
I use this: Goobay 64876 Multiswitch
Could this be a driver problem? Or if it works, I shouldn't bother with it?
root@vpsend:~# dvb-fe-tool --adapter=0 --frontend=0
Device TurboSight TBS 6905 DVB-S/S2 (/dev/dvb/adapter0/frontend0) capabilities:
CAN_2G_MODULATION
CAN_FEC_AUTO
CAN_INVERSION_AUTO
CAN_MULTISTREAM
CAN_QPSK
DVB API Version 5.12, Current v5 delivery system: DVBS
Supported delivery systems:
[DVBS]
DVBS2
DSS
Frequency range for the current standard:
To: 2.15 GHz
Symbol rate ranges for the current standard:
To: 70.0 MBauds
SEC: set voltage to OFF
root@vpsend:~# dvb-fe-tool --adapter=1 --frontend=0
Device TurboSight TBS 6905 DVB-S/S2 (/dev/dvb/adapter1/frontend0) capabilities:
CAN_2G_MODULATION
CAN_FEC_AUTO
CAN_INVERSION_AUTO
CAN_MULTISTREAM
CAN_QPSK
DVB API Version 5.12, Current v5 delivery system: DVBS2
DVBS
[DVBS2]
DSS
To: 2.15 GHz
To: 70.0 MBauds
root@vpsend:~# dvb-fe-tool --adapter=2 --frontend=0
Device TurboSight TBS 6905 DVB-S/S2 (/dev/dvb/adapter2/frontend0) capabilities:
CAN_2G_MODULATION
CAN_FEC_AUTO
CAN_INVERSION_AUTO
CAN_MULTISTREAM
CAN_QPSK
DVBS
[DVBS2]
DSS
To: 2.15 GHz
To: 70.0 MBauds
root@vpsend:~# dvb-fe-tool --adapter=3 --frontend=0
Device TurboSight TBS 6905 DVB-S/S2 (/dev/dvb/adapter3/frontend0) capabilities:
CAN_2G_MODULATION
CAN_FEC_AUTO
CAN_INVERSION_AUTO
CAN_MULTISTREAM
CAN_QPSK
DVBS
[DVBS2]
DSS
To: 2.15 GHz
To: 70.0 MBauds
root@vpsend:~# dvb-fe-tool --adapter=4 --frontend=0
Device TurboSight TBS 6909 DVB-S/S2 (/dev/dvb/adapter4/frontend0) capabilities:
CAN_2G_MODULATION
CAN_FEC_AUTO
CAN_INVERSION_AUTO
CAN_QPSK
DVBS
[DVBS2]
DSS
To: 2.35 GHz
To: 45.0 MBauds
root@vpsend:~# dvb-fe-tool --adapter=5 --frontend=0
Device TurboSight TBS 6909 DVB-S/S2 (/dev/dvb/adapter5/frontend0) capabilities:
CAN_2G_MODULATION
CAN_FEC_AUTO
CAN_INVERSION_AUTO
CAN_QPSK
[DVBS]
DVBS2
DSS
To: 2.35 GHz
To: 45.0 MBauds
root@vpsend:~# dvb-fe-tool --adapter=6 --frontend=0
Device TurboSight TBS 6909 DVB-S/S2 (/dev/dvb/adapter6/frontend0) capabilities:
CAN_2G_MODULATION
CAN_FEC_AUTO
CAN_INVERSION_AUTO
CAN_QPSK
[DVBS]
DVBS2
DSS
To: 2.35 GHz
To: 45.0 MBauds
....etc
dmesg | grep TBS
[ 32.569492] TBSECP3 driver 0000:01:00.0: TurboSight TBS 6905 DVB-S/S2
[ 32.570335] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 32.692620] TBSECP3 driver 0000:01:00.0: MAC address 00:22:ab:91:6b:5c
[ 32.830125] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6905 DVB-S/S2 )...
[ 32.830218] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 32.952616] TBSECP3 driver 0000:01:00.0: MAC address 00:22:ab:91:6b:5d
[ 32.952637] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6905 DVB-S/S2 )...
[ 32.952752] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 33.028592] TBSECP3 driver 0000:01:00.0: MAC address 00:22:ab:91:6b:5e
[ 33.059615] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6905 DVB-S/S2 )...
[ 33.059664] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 33.164601] TBSECP3 driver 0000:01:00.0: MAC address 00:22:ab:91:6b:5f
[ 33.164612] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6905 DVB-S/S2 )...
[ 33.164670] TBSECP3 driver 0000:01:00.0: TurboSight TBS 6905 DVB-S/S2 : PCI 0000:01:00.0, IRQ 44, MMIO 0xfb700000
[ 33.164814] TBSECP3 driver 0000:03:00.0: TurboSight TBS 6909 DVB-S/S2
[ 33.165966] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 33.288657] TBSECP3 driver 0000:03:00.0: MAC address 00:22:ab:92:8f:a0
[ 57.910584] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 4 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 57.910704] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 58.033642] TBSECP3 driver 0000:03:00.0: MAC address 00:22:ab:92:8f:a1
[ 58.033679] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 5 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 58.033726] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 58.156658] TBSECP3 driver 0000:03:00.0: MAC address 00:22:ab:92:8f:a2
[ 58.156671] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 6 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 58.156732] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 58.279679] TBSECP3 driver 0000:03:00.0: MAC address 00:22:ab:92:8f:a3
[ 58.279690] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 7 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 58.279752] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 58.402696] TBSECP3 driver 0000:03:00.0: MAC address 00:22:ab:92:8f:a4
[ 58.402707] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 8 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 58.402769] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 58.525731] TBSECP3 driver 0000:03:00.0: MAC address 00:22:ab:92:8f:a5
[ 58.525741] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 9 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 58.525798] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 58.648724] TBSECP3 driver 0000:03:00.0: MAC address 00:22:ab:92:8f:a6
[ 58.648735] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 10 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 58.648797] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[ 58.771730] TBSECP3 driver 0000:03:00.0: MAC address 00:22:ab:92:8f:a7
[ 58.771741] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 11 frontend 0 (TurboSight TBS 6909 DVB-S/S2 )...
[ 58.771797] TBSECP3 driver 0000:03:00.0: TurboSight TBS 6909 DVB-S/S2 : PCI 0000:03:00.0, IRQ 45, MMIO 0xfb600000
[ 62.024075] TBSECP3 driver 0000:01:00.0: DVB: adapter 0 frontend 0 frequency 0 out of range (950000..2150000)
[ 62.027920] TBSECP3 driver 0000:01:00.0: DVB: adapter 1 frontend 0 frequency 0 out of range (950000..2150000)
[ 62.030015] TBSECP3 driver 0000:01:00.0: DVB: adapter 2 frontend 0 frequency 0 out of range (950000..2150000)
[ 62.032674] TBSECP3 driver 0000:01:00.0: DVB: adapter 3 frontend 0 frequency 0 out of range (950000..2150000)
[ 62.033531] TBSECP3 driver 0000:03:00.0: DVB: adapter 4 frontend 0 frequency 0 out of range (300000..2350000)
[ 62.034415] TBSECP3 driver 0000:03:00.0: DVB: adapter 5 frontend 0 frequency 0 out of range (300000..2350000)
[ 62.035585] TBSECP3 driver 0000:03:00.0: DVB: adapter 6 frontend 0 frequency 0 out of range (300000..2350000)
[ 62.036460] TBSECP3 driver 0000:03:00.0: DVB: adapter 7 frontend 0 frequency 0 out of range (300000..2350000)
[ 62.037294] TBSECP3 driver 0000:03:00.0: DVB: adapter 8 frontend 0 frequency 0 out of range (300000..2350000)
[ 62.038206] TBSECP3 driver 0000:03:00.0: DVB: adapter 9 frontend 0 frequency 0 out of range (300000..2350000)
[ 62.039049] TBSECP3 driver 0000:03:00.0: DVB: adapter 10 frontend 0 frequency 0 out of range (300000..2350000)
[ 62.039941] TBSECP3 driver 0000:03:00.0: DVB: adapter 11 frontend 0 frequency 0 out of range (300000..2350000)
nszerver
Re: ERROR FE_SET_VOLTAGE: Operation not permitted
Postby smile » Thu Jun 19, 2025 10:44 am
hello
it might be a problem of mismatched DVBAPI.
Could you try the dvblast?
smile
Postby nszerver » Thu Jun 19, 2025 2:32 pm
Hello, how tvheadend only check dvb.
how dvblast
nszerver
Postby smile » Thu Jun 19, 2025 2:56 pm
such as
dvblast -f 12660000 -s 45000000 -m psk_8 -5 dvbs2 -v 13 -a 0
smile
