Error lastest pve
Error lastest pve
Postby nszerver » Wed Jun 18, 2025 3:41 am
Error lastest pve
make -C /root/tbsdriver/media_build/v4l install
make[1]: Entering directory '/root/tbsdriver/media_build/v4l'
Hmm... distro kernel with a non-standard place for module backports detected.
Please always prefer to use vanilla upstream kernel with V4L/DVB
I'll try to remove old/obsolete LUM files from /lib/modules/6.8.12-11-pve//updates/dkms:
find: warning: '-name' matches against basenames only, but the given pattern contains a directory separator ('/'), thus the expression will evaluate to false all the time. Did you mean '-wholename'?
Installing kernel modules under /lib/modules/6.8.12-11-pve/updates/extra/media/:
../misc/altera-stapl/: altera-stapl.ko
pci/tbsecp3/: tbsecp3.ko
cec/core/: cec.ko
tuners/: tuner-types.ko tuner-simple.ko si2157.ko
dvb-frontends/: tas2101.ko si2168.ko
cec/usb/pulse8/: pulse8-cec.ko
dvb-core/: dvb-core.ko
/sbin/depmod -a 6.8.12-11-pve
make -C firmware install
make[2]: Entering directory '/root/tbsdriver/media_build/v4l/firmware'
Installing firmwares at /lib/firmware:
make[2]: Leaving directory '/root/tbsdriver/media_build/v4l/firmware'
make[1]: Leaving directory '/root/tbsdriver/media_build/v4l'
nszerver
Re: Error lastest pve
Postby smile » Tue Jun 24, 2025 2:56 pm
it seem without any error.
Best Regards
smile
Postby nszerver » Thu Jul 03, 2025 4:26 am
error logs:
Jul 02 21:49:20 vpsend tvheadend[1264]: spawn: [aist#0:2/mp2 @ 0x5cfc349bce00] timestamp discontinuity (stream id=5112): 10032000, new offset= -98056000
Jul 02 21:49:20 vpsend tvheadend[1264]: spawn: [vist#0:1/mpeg2video @ 0x5cfc349bed80] timestamp discontinuity (stream id=5111): -10032000, new offset= -88024000
Jul 02 21:49:21 vpsend tvheadend[1264]: spawn: [aist#0:2/mp2 @ 0x5cfc349bce00] timestamp discontinuity (stream id=5112): 10032000, new offset= -98056000
Jul 02 21:49:21 vpsend tvheadend[1264]: spawn: [vist#0:1/mpeg2video @ 0x5cfc349bed80] timestamp discontinuity (stream id=5111): -10032000, new offset= -88024000
Jul 02 21:49:22 vpsend tvheadend[1264]: spawn: [aist#0:2/mp2 @ 0x5cfc349bce00] timestamp discontinuity (stream id=5112): 10032000, new offset= -98056000
Jul 02 21:49:22 vpsend tvheadend[1264]: spawn: [vist#0:1/mpeg2video @ 0x5cfc349bed80] timestamp discontinuity (stream id=5111): -10032000, new offset= -88024000
Jul 02 21:49:23 vpsend tvheadend[1264]: spawn: [aist#0:2/mp2 @ 0x5cfc349bce00] timestamp discontinuity (stream id=5112): 10032000, new offset= -98056000
Jul 02 21:49:23 vpsend tvheadend[1264]: spawn: [vist#0:1/mpeg2video @ 0x5cfc349bed80] timestamp discontinuity (stream id=5111): -10032000, new offset= -88024000
T
nszerver
Postby smile » Fri Jul 04, 2025 11:42 am
Hello
it is the PCR jitter.
it does not matter.
smile
