Win 11 Drivers (support HVCI)
Postby smile » Tue May 20, 2025 10:18 am
Hello everyone
We will be updating the new Win11 drivers. it support HVCI (PS. enable the memory integrity ).We apologize for the delay. All products will be updated to support Win11 drivers in sequence. Due to the large number of products, this process will take some time. Please visit the respective product download pages to download the drivers. any issues ,please feedback to here,we will check them and fixed it. The following products are now supported:
TBS5930: https://www.tbsiptv.com/download/tbs5930/tbs5930_release_v11008_20250606_win11.zip
TBS5530: https://www.tbsiptv.com/download/tbs5530/TBS5530_release_v2.1.0.2_win11.zip
TBS5520SE: https://www.tbsiptv.com/download/tbs5520se/TBS5520SE_release_win11_v1108_250523.zip
TBS5580: https://www.tbsiptv.com/download/tbs5580/TBS5580_release_v1104_win11.zip
TBS6904SE: https://www.tbsiptv.com/download/tbs6904se/TBS6904SE_release_v1104_win11_20250528.zip
TBS6205SE :https://www.tbsiptv.com/download/tbs6205se/TBS6205SE_release_v1102_win11.zip
TBS6209SE: https://www.tbsiptv.com/download/tbs6209se/TBS6209SE_release_v2102_win11.zip
TBS5230:https://www.tbsiptv.com/download/tbs5230/tbs5230_release_v1.1.0.2_win11.zip
TBS5590:https://www.tbsiptv.com/download/tbs5590/TBS5590_drivers_release_V2.1.0.3_win11.zip
TBS6910SE:https://www.tbsiptv.com/download/tbs6910se/TBS6910SE_release_v1102_win11.zip
TBS6522H:https://www.tbsiptv.com/download/tbs6522h/tbs6522h_release_v2101_win11_250612.zip
TBS6902:https://www.tbsiptv.com/download/tbs6902/tbs6902_release_v1106_win11.zip
TBS6590:https://www.tbsiptv.com/download/tbs6590/tbs6590_release_V1115_win11.zip
TBS6522:https://www.tbsiptv.com/download/tbs6522/tbs6522_release_v1115_win11.zip
TBS5927:https://www.tbsiptv.com/download/tbs5927/tbs5927_release_drivers_v1104_win11.zip
TBS6504:https://www.tbsiptv.com/download/tbs6504/tbs6504_release_v1106_win11.zip
TBS6508:https://www.tbsiptv.com/download/tbs6508/TBS6508_release_v1.0.0.2.zip
TBS5930Lite:https://www.tbsiptv.com/download/tbs5930_lite/TBS5930lite_release_v1103_win11.zip
TBS6903X:https://www.tbsiptv.com/download/tbs6903x/tbs6903x_release_v2105_win11.zip
TBS6281se_v2:https://www.tbsiptv.com/download/tbs6281se_v2/tbs6281se_v2_release_v2101_win11.zip
TBS6514:https://www.tbsiptv.com/download/tbs6514/tbs6514_release_v2101_win11.zip
Best Regards
smile
Re: Win 11 Drivers (support HVCI)
Postby Babadem » Mon Jul 07, 2025 7:14 am
Do you first uninstall TBS6903x_release_v2005 before installing tbs6903x_release_v2105_win11, or install the new release with the old one?
Edit: I uninstalled v2005 and then installed v2105_win11.
Babadem
Postby smile » Mon Jul 07, 2025 11:30 am
Hello
both are ok.
if you install it directly, it will cover the older version.
Best Regards
smile
Postby Babadem » Tue Jul 08, 2025 1:43 am
Can you post the Release notes listing the changes associated with tbs6903x_release_v2105_win11?
Babadem
Postby DVB » Wed Jul 09, 2025 10:25 am
Drivers for TBS 5927 cannot be installed - during install there's BSOD: PAGE FAULT IN NONPAGED AREA
Is it a proper version? 5927 drivers for Win10 have version 1.0.0.7, and for Windows 11 instead of expected 1.1.0.7 - 1.1.0.4
And now you're watching 8K:
KKKKKKKK
DVB
Postby smile » Wed Jul 09, 2025 10:40 am
DVB Wrote:Drivers for TBS 5927 cannot be installed - during install there's BSOD: PAGE FAULT IN NONPAGED AREA
Hello sir,
This drivers just support for the Win 11 system. it support enable the memory integrity.
Best Regards
smile
Postby smile » Wed Jul 09, 2025 10:42 am
Babadem Wrote:Can you post the Release notes listing the changes associated with tbs6903x_release_v2105_win11?
hello sir,
It merely undergoes optimization and updates to enable support for the HVCI of Win11.
Best Regards
smile
Postby DVB » Wed Jul 09, 2025 10:58 am
Hello sir,
Best Regards
Yes, I know that :) The thing is that this driver does not work and cannot be installed.
And even worse - it resulted that every reconnect of TBS5927 to PC is resulting in BSOD.
I had to manually remove tbs5927.inf/sys with DriverStoreExplorer and roll back to 1.0.0.7.
No problems with e.g. 5590 Win11 driver on the same machine.
KKKKKKKK
DVB
Postby smile » Thu Jul 10, 2025 4:36 pm
Hello sir,
Best Regards
please try this drivers :
https://www.tbsiptv.com/download/tbs592 ... _win11.zip
smile
Postby DVB » Thu Jul 10, 2025 6:25 pm
smile Wrote:please try this drivers :
Thanks - fixed & works properly now :)
KKKKKKKK
DVB
Return to Win11 Drivers
