tbs 6982
tbs 6982
Postby wandro101 » Wed May 14, 2025 3:11 am
I have a TBS 6982 will the tbs6982 work with a wideband lnb ??
wandro101
Re: tbs 6982
Postby DVB » Wed May 14, 2025 4:23 am
Directly no and there's no DVB card which would correctly work directly with Wideband LNB. For Wideband LNB tuner has to be able to receive signal starting from around 290 MHz up to 2340 MHz. Tuning range for 6982: 950~2150 MHz
You can use multiswitch between to "convert" wideband signal back to universal one.
And now you're watching 8K:
KKKKKKKK
DVB
Re: tbs 6982
Postby crazycat » Thu May 15, 2025 3:53 am
TBS 6983, 6903/5/8, 5927 have wide-band tuner STV6120
Re: tbs 6982
Postby DVB » Thu May 15, 2025 6:01 am
Yes, but based on STV6120 specs - still not wide enough - up to 2150 MHz, when up to 2340 MHz is needed. Ignoring the software support for a moment - in the best case around 150-200 MHz from high band might be gone (~12,550-12,600+)...
KKKKKKKK
DVB
