Debian 12 - TBS5930 - tvheadend installation
2021 New Arrival! digital satellite external TV tuner box TBS5930 DVB-S/S2/S2X TV Tuner USB card.
Postby VanDannyPTY » Thu Feb 27, 2025 6:14 am
here is how got my TB5930 install in my Debian 12 homelab "server"
root@debian:~# uname -r
6.12.9+bpo-amd64
apt install linux-headers-$(uname -r)
apt install libproc-processtable-perl patchutils gcc build-essential git libdigest-sha-perl build-essential subversion mercurial openssl gettext libssl-dev screen libv4l-dev -y
cd media_build
make dir DIR=../media
make distclean
make allyesconfig
sed -i -r 's/(^CONFIG.*_RC.*=)./\1n/g' v4l/.config
sed -i -r 's/(^CONFIG.*_IR.*=)./\1n/g' v4l/.config
make -j2
sudo make install
wget http://www.tbsdtv.com/download/document ... .0.tar.bz2
sudo tar jxvf tbs-tuner-firmwares_v1.0.tar.bz2 -C /lib/firmware/
systemctl reboot
tvheadend installation:
curl -1sLf 'https://dl.cloudsmith.io/public/tvheadend/tvheadend/setup.deb.sh' | sudo -E bash
apt install tvheadend
VanDannyPTY
Re: Debian 12 - TBS5930 - tvheadend installation
Postby smile » Thu Mar 06, 2025 11:53 am
hello
please check the user guide:
https://www.tbsiptv.com/download/tbs593 ... Manual.pdf
best regards
smile
Postby VanDannyPTY » Wed Mar 19, 2025 7:02 am
smile Wrote:hello
best regards
I did followed this instructions, however it doesn´t work for debian, only ubuntu
VanDannyPTY
Postby steven » Wed Mar 19, 2025 9:47 am
when you install any error logs ? or you can setup SSH remote send to our support@tbsdtv.com
we will have a check
Return to DVB-S2X/S2 TV Tuner USB Card TBS5930
