YA VDR problem No rule to make target
Postby Gorefest » Wed May 26, 2010 7:07 pm
When I do "make"
I get following error:
make -C /home/ignard/Downloads/linux-s2api-tbs6980/v4l
make[1]: Map '/home/ignard/Downloads/linux-s2api-tbs6980/v4l' wordt binnengegaan
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/home/ignard/Downloads/linux-s2api-tbs6980/v4l/firmware'
make[2]: Leaving directory `/home/ignard/Downloads/linux-s2api-tbs6980/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for `default'.
Kernel build directory is /lib/modules/2.6.31-21-generic/build
make -C /lib/modules/2.6.31-21-generic/build SUBDIRS=/home/ignard/Downloads/linux-s2api-tbs6980/v4l modules
make[2]: Entering directory `/usr/src/linux-headers-2.6.31-21-generic'
make[3]: *** No rule to make target `/home/ignard/Downloads/linux-s2api-tbs6980/v4l/tbs6980ctrl.o', needed by `/home/ignard/Downloads/linux-s2api-tbs6980/v4l/tda18271.o'. Stop.
make[2]: *** [_module_/home/ignard/Downloads/linux-s2api-tbs6980/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-2.6.31-21-generic'
make[1]: *** [default] Fout 2
make[1]: Map '/home/ignard/Downloads/linux-s2api-tbs6980/v4l' wordt verlaten
make: *** [all] Fout 2
Any Idea what is wrong?
Gorefest
Re: YA VDR problem No rule to make target
Postby cody » Thu May 27, 2010 9:39 am
please, read the "README" file that is part of Linux driver package for TBS 6980 the relevant part for your problem is:
I.3 depending on if the kernel is x86 or x86_64 (check output of 'uname -a') do:
- for x86 kernel (x86 32 bit installations of Linux):
# cp v4l/tbs6980ctrl.o.x86 v4l/tbs6980ctrl.o
# cp v4l/tbs6980fe_driver.o.x86 v4l/tbs6980fe_driver.o
- for x86_64 kernel (x86 64 bit installations of Linux):
# cp v4l/tbs6980ctrl.o.x86_64 v4l/tbs6980ctrl.o
# cp v4l/tbs6980fe_driver.o.x86_64 v4l/tbs6980fe_driver.o
that should fix your problem.
Postby Gorefest » Thu Jun 03, 2010 2:03 am
I'm sure I did that.... anyway I have completely re-installed ubuntu and got it working.
Thanks!
Gorefest
