[ Moderator Control Panel ]
by JuhaFinland » Thu Oct 24, 2024 3:43 pm
I try to compile v20240829 in Silverblue Toolbox in the Fedora system. No luck. It has such a errors and no dependencies. It seems impossible task to do.
Dependencies resolved.
Nothing to do.
Complete!
No file to patch. Skipping patch.
1 out of 1 hunk ignored
Applying patches for kernel 6.11.4-201.fc40.x86_64
6 11 4
firmware file not exist!!!
JuhaFinland
by JuhaFinland » Sat Nov 02, 2024 11:53 pm
After deployment of make dir DIR=../media
Can't locate File/Copy.pm in @INC (you may need to install the File::Copy module) (@INC entries checked: /usr/local/lib64/perl5/5.40 /usr/local/share/perl5/5.40 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5) at ./use_dir.pl line 5.
BEGIN failed--compilation aborted at ./use_dir.pl line 5.
make[1]: *** [Makefile:128: dir] Error 2
make[1]: Leaving directory '/opt/media_build/linux'
make: *** [Makefile:32: dir] Error 2
also I did /build --check-only giving four dependencies what I did install. What is Copy module. I am inside Toolbox in the Silverblue not to make trouble when simple driver compile is so difficult.
JuhaFinland
by JuhaFinland » Tue Nov 05, 2024 6:56 pm
You do need to type whole link to be directly executive. Also there is error perl Makefile.PL
Can't locate ExtUtils/MakeMaker.pm in @INC (you may need to install the ExtUtils::MakeMaker module)
So I do need an other whatever to able execute make. In first try /build --check- check all and install perl and SHA. It become too difficult to compile. I know that there is a lot Silverblue users and tv card owners. So difficult to make simple driver.
JuhaFinland
by zhangchao » Fri Nov 08, 2024 11:01 am
hi,
if the fresh system is ubuntun , debian , no need to install SHA and perl-proc from source .
if the fresh system is centos , fedora , need to install from source .
you can add skype jack_2431 if has issue in installing drivers.
best regards!
zhangchao
Users browsing this forum: No registered users and 13 guests
