Channels are not being descrambled in the new PC
Postby RomanSin » Fri Jul 12, 2024 4:09 am
After changing my PC (from Windows 10 to Windows 11, from Z87 to Z790 chipset) my TBS6590 gave up showing the scrambled DVB-C channels though I sequentially put to DVBViewer program folder three different versions of TbsCIapi.dll: 1.0.2.2 of March 7, 2018; 1.0.2.3 of May 17, 2019; and 1.0.2.3 of May 5, 2023 (from DVB Dream v298). In the last two cases, DVBViewer just crashed. The free channels are available. What should I do?
RomanSin
Re: Channels are not being descrambled in the new PC
Postby smile » Fri Jul 12, 2024 9:44 am
hi
Do you install the latest drivers (V1.0.1.4)?
and install the latest version of dvbdream or dvbviewer from the office web.
Best Regards
smile
Postby RomanSin » Sat Jul 13, 2024 1:06 am
Yes, the current version of the driver is 1.0.1.4 and the version of DVBViewer is 7.3.0.0.
RomanSin
Postby EnoSat » Tue Jul 16, 2024 3:54 pm
Maybe he will still be needed Microsoft Visual C++ 2008 Service Pack 1
EnoSat
Postby RomanSin » Wed Jul 17, 2024 4:14 am
It was installed so the issue is not here
RomanSin
Postby smile » Thu Jul 18, 2024 3:41 pm
please try the tools
https://www.tbsiptv.com/download/common ... 0.0.10.zip
the tools will read the CAM MMI info.
BTW. check your CAM if expired.
Best Regards
smile
Postby RomanSin » Sat Aug 03, 2024 1:28 am
The CAM is not expired, it works in the older third-party tuner as well as in my TV.
RomanSin
Postby smile » Wed Aug 07, 2024 9:19 am
Hi sir
From the pictures, the CAM was not deceted, is the CAM's light on? Could you show me the pictures the card with CAM ?
or Could you give me the remote access to check it? email to me Davin@tbsdtv.com
Best Regards
smile
Postby RomanSin » Wed Aug 07, 2024 1:19 pm
The green light is on, the external power is connected too as you see.
RomanSin
Postby steven » Mon Aug 12, 2024 9:10 am
Hi Sir,
Please setup the remote and send email to davin he will have a remote check with this .
