TBS 6909X V2 NORMAL MODE=1
Postby achilless » Sun Jun 23, 2024 5:56 am
Hello dear users.
my configuration is like this
quattro lnb to multiswitch and then tbs6909x
6909x works only mode=1 but problem is here.
every tuner must be work like this
If adapter0 VL then adapter1 must be VL
If adapter0 VL then adapter1 VH ( it does not work )
my question is every two tuner has to be work with Vertical or Horizantal ? ninstead of Low-band or High-band ?
achilless
Re: TBS 6909X V2 NORMAL MODE=1
Postby crazycat » Sun Jun 23, 2024 9:43 pm
Every two tuner work in same polarization (same LNB voltage) and band (continous 22KHz tone)
I your case better use mode=0 (default mode) if only one LNB connected to multiswitch (or direct quattro/quad LNB connection to card)
Postby achilless » Tue Jun 25, 2024 6:51 pm
I have multiswitch 17/40 with quattro lnb VL VH HL HH
At this configuration i can choose 4 satellites by diseqc.
i choose mode-0 ( signal faild )
i choose mode-1 only works like this
For example
If adapter-0 —> VL then adapter-1 has to be —> VL
How can i get signal on every two adapter no matter band it is low or high ?
In this example it did not work
Adapter-0 —> VL
adapter-1 —> VH
How to use like this ?
achilless
Postby crazycat » Wed Jun 26, 2024 3:37 am
mode 0 not pass diseqc cmd, so only first LNB accessible
