TBS6902 Motor Disc compatibility
Postby aramrahgozar » Tue Jun 11, 2024 5:31 pm
I have a question before purchase my card. Base on the below post, I assume This card will work with motor disc, am I right? Because in the guide It doesn't say it work with motor, It says "DiSEqC 2.0, Unicable".
I use DVBViewer.
viewtopic.php?f=183&t=10115
aramrahgozar
Re: TBS6902 Motor Disc compatibility
Postby crazycat » Tue Jun 11, 2024 10:17 pm
Motor use DiseqC protocol (including USALS extension), so hw supported if used software support DiseqC motor control.
