Can TBS2925 MOI Smart Box Record Satellite Streams to NAS
Postby Mediamonitor » Sat May 25, 2024 1:51 am
Hello
I am thinking of getting the TBS2925 MOI Smart Box with the 6909x octatuner card and set it up via TVHeadend to record 8 Channels simultaneous continuously.
Will this system be able to do that?
For example select 8 channels and setup tvheadend to record each channel in one hour segments in order to cover the full 24 hours and set the device to record over the network on a NAS drive
Has this been done before? any other recommendations? Please share your thoughts on the process and if its doable? or if you suggest a different setup
Mediamonitor
Re: Can TBS2925 MOI Smart Box Record Satellite Streams to NA
Postby Mediamonitor » Fri May 31, 2024 2:31 am
I didnt understand your answer
So is this something doable and reliable?
Mediamonitor
Postby steven » Tue Jun 11, 2024 10:43 am
Hi Sir,
Sure you can check this guide from tvheadend you can record to your NAS:
https://tvheadend.org/d/8261-tvheadend-recordings-to-nas/2
Return to MOI DVB-S2 Streaming Box
