[ Moderator Control Panel ]
TBS8112 is a compact trans-modulation device that is used to convert free DVB-S/S2/S2X satellite TV channels to DVB-T (Digital Terrestrial Television) format. It supports to receive free satellite channels from 4 frequencies via 4 RF port, and output DVB-T channels in 4 frequencies.
by skysat » Fri May 03, 2024 1:13 pm
i have a problem with TBS 8113,when i want to save input http network TS stream in tbswebui says "fail",i tried all possible but whithout success.
DVB-S2 input stream save normally.
Can you give me any advice
Thanks advanced!
- Attachments
skysat
by zhangchao » Tue May 28, 2024 9:40 am
hi ,
please add skype jack_2431 . i will check with you .
best regards!
zhangchao
Return to TBS8112 DVB-S/S2/S2X TO DVB-T Trans-Modulator
