TBS5520SE - Driver issue with rpi4 kernel 6.1.0
Postby mcrlecce » Wed Feb 14, 2024 10:44 am
I'm attempting to install a driver for the TBS5520SE on my Raspberry Pi 4, which is running the latest OS, Bookworm, with kernel version 6.1.0. The installation process appears to have completed, but the device is still not recognized in TVheadend. Could someone assist me? What instructions should I follow to install the driver on this new kernel?
mcrlecce
Re: TBS5520SE - Driver issue with rpi4 kernel 6.1.0
Postby zhangchao » Sun Feb 18, 2024 5:52 pm
You can modify your build instructions as follows:
sudo apt-get install git mc patchutils raspberrypi-kernel-headers libproc-processtable-perl -y
cd media_build
make dir DIR=../media
make allyesconfig
sed -i -r 's/(^CONFIG.*_RC.*=)./\1n/g' v4l/.config
sed -i -r 's/(^CONFIG.*_IR.*=)./\1n/g' v4l/.config
####### Next instructions only on 32-bit system ##################
sed -i 's/CONFIG_VIDEO_SAA7146_VV=m/#CONFIG_VIDEO_SAA7146_VV is not set/g' v4l/.config
make -j4
sudo make install
wget http://www.tbsdtv.com/download/document ... .0.tar.bz2
sudo tar jxvf tbs-tuner-firmwares_v1.0.tar.bz2 -C /lib/firmware
zhangchao
Postby mcrlecce » Mon Feb 19, 2024 8:45 am
zhangchao Wrote:You can modify your build instructions as follows:
cd media_build
make allyesconfig
make -j4
sudo make install
Hi Zhangchao,
Thank you very much for the response. I've followed your instructions, and now the TBS5520se is correctly recognized by the operating system, and Tvheadend works properly. I've also installed it on my new Raspberry Pi 5 without any issues.
Cheers
mcrlecce
