Transponders missing
Postby Delta1Star » Sun Nov 19, 2023 4:58 pm
Hello members,
I miss a Transponder list in Moi Pro when I want to use a program.
Best regards
Delta1Star
Re: Transponders missing
Postby Delta1Star » Sun Nov 19, 2023 5:01 pm
Delta1Star Wrote:Hello members,
Best regards
This transponder list is via a TBS5927 USB box
Delta1Star
Postby steven » Wed Nov 22, 2023 9:50 am
Hi sir,
You need manual input the frequency like this:
pic
and your MOIPro using 6985 only support 4x frequenies at the same time.
Postby Delta1Star » Thu Nov 23, 2023 3:46 am
Steven, I'm lucky, I get into the program list. What now.
Delta1Star
Postby Delta1Star » Fri Nov 24, 2023 3:48 am
Hello members,
is there any of you who can assist me.
I can receive the channels, because I get or have a lock, now I still need the image, how do I do that
Best regards
Delta1Star
Postby DVB » Fri Nov 24, 2023 7:25 am
Now stream and watch :) If you can see channels in Dvblast - it's super easy now - select service - mark wich checkbox and press button on the bottom of list.
Use any media player on PC, enter given IP and you're done here - you can watch.
After that you can think on advanced config. Always step by step, firstly simple action, then go deep.
PS: I'll answer on PW at weekend - sorry I'm a bit busy :(
And now you're watching 8K:
KKKKKKKK
DVB
Postby Delta1Star » Fri Nov 24, 2023 9:48 pm
Nothing happens in VLC.
no matter what I try.
Delta1Star
Postby Delta1Star » Mon Nov 27, 2023 2:41 pm
Whatever I try with udp://239.255.0.1:1234 or rtp://239.255.0.1:1234
Via the VLC media player or MPC-HC
nothing happens.
I receive a notification via MPC-HC;
Failed to render the file.
Best regards
Delta1Star
Postby DVB » Mon Nov 27, 2023 3:33 pm
Why 239.255.0.1? Did you selected first channel? Show screenshot.
KKKKKKKK
DVB
Postby Delta1Star » Mon Nov 27, 2023 3:56 pm
Screen-shot
Delta1Star
Return to General discussion
