TBS6290SE windows drivers..
Postby Charrofmine » Wed Nov 15, 2023 10:09 am
Hey! I had this card working fine previously (although i remember having a bit of a fight getting it to work, just cant remember what the fight was about lol)..The cards been sitting in storage, and now i need it again..However, i cant get it to work in win 10 pro..Only 1 driver available (TBS6290SE Windows Driver V1.0.0.1.) for download and it just wont get past such state: https://i.imgur.com/7t3XwzC.jpg
Are there perhaps some beta drivers i could try? Any tips? I really need this thing working as soon as possible, and am desperate..It has worked fine in the same OS before, been kept well/the hardware recognized just the drivers will not do anything no matter if i install them in win7 compatible mode and/or as administrator..
Please help..
-C
Charrofmine
Re: TBS6290SE windows drivers..
Postby crazycat » Thu Nov 16, 2023 4:27 am
TBS6290SE 1.0.0.1 driver is vendor-signed for Win Vista (6.0) and later.
Win10 x64 require WHQL-signed driver (after 2016 update).
Postby Charrofmine » Thu Nov 16, 2023 4:36 am
crazycat Wrote:TBS6290SE 1.0.0.1 driver is vendor-signed for Win Vista (6.0) and later.
Where can i find the driver? Not on tbs's site it only lists that single old driver unfortunately.. :/
Charrofmine
Postby smile » Mon Jan 22, 2024 10:09 am
Hi sir
i think you use the older hareware version before 2017. so please install this version
dvbt: https://www.tbsiptv.com/download/tbs629 ... .0.0.2.zip
dvbc : https://www.tbsiptv.com/download/tbs629 ... .0.0.2.zip
BTW. for the win11, please disable memory integrity in windows 11 security.
Best Regards
smile
Return to DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290SE
