TBS5520SE Windows 11 driver
Postby vertexview » Wed Aug 30, 2023 5:04 pm
I'm currently using the TBS5520se receiver running Windows 10 Pro (22H2) on my desktop computer. It works without problem with DVB viewer Pro, AltDVB, Crazyscan.
I tried to install your latest known TBS driver (1.0.0.8) on my Windows 11 laptop,... without success.
A popup window informs me that this driver is not compatible with the OS !
Is there a possibility to update your driver repository to have full compatibility with Windows 11 ?
Thanks.
vertexview
Re: TBS5520SE Windows 11 driver
Postby DVB » Wed Aug 30, 2023 5:22 pm
I'm using TBS5520SE on Windows 11 without any issues, but on driver 1.0.0.7.
1.0.0.8 beta driver is buggy (DiSEqC issues).
And now you're watching 8K:
KKKKKKKK
DVB
Postby vertexview » Wed Aug 30, 2023 9:59 pm
@ DVB
Thanks for your help.
I tried installing the 1.0.0.7 driver, but had the same problem as in the 1.0.0.8 setup.
Something is wrong with TBS5520Se.sys. Driver loading is blocked by a Windows 11 security setting.
I don't want to disable the Memory Integrity setting in Windows Security...
Nom du pilote : oem80.inf
GUID de classe : {4d36e96c-e325-11ce-bfc1-08002be10318}
Service : tbsBDA.TBS5520
Filtres inférieurs :
Filtres supérieurs :
Problème : 0x0
État du problème : 0xC00000E5
vertexview
Postby vertexview » Sun Sep 10, 2023 12:43 am
The TBS5520se driver (TBS5520Se.sys) is not compatible with Windows Security Core isolation mode.
By default, this mode is disabled in Windows 10 and enabled in Windows 11.
I uninstalled all the "old drivers" in Windows 10 and TBS5520Se.sys is the latest driver that blocks the Memory Integrity setting from being enabled (useful against Trojans !...)
I would like to know if new developments of TBS drivers are planned to allow compatibility with this Microsoft mode, now native in Windows 11 ?
vertexview
