Active front end stats via udp.
Postby vk3eht » Sun Jun 25, 2023 11:16 am
I’m a happy owner of a MOI-Pro AMD. I have 2 cards
1x TBS6281SE DVB-T2/T/C TV Dual Tuner PCIe Card
1x TBS6902 DVB-S2/S Dual TV Tuner PCIe Card
I require to monitor each front end for a signal lock on any one of the 4 tuner frontends. Once a lock is available, I round robin send signal level, BER SNR every 500ms independent of each other via a UDP socket out to another bit of kit which switches a listener to the locked signal.
Basically a require a background task for each frontend or one task to monitor each fe and report via a UDP.
Example on UDP channels.
Frontend 0 UDP 6660
Frontend 1 UDP 6661
Frontend 2 UDP 6662
Frontend 3 UDP 6663
Why you say?
I’m using my MOI for a club repeater project with set frequencies which aren’t always receiving a TS stream. Mute till a signal lock is receiver, then begins sending TS and fe stats.
Is there a way to do this?
Can a small C program be run in the background?
Does the MOI have gcc and linker with header libraries installed to compile code to do such?
I’m using MuMuDVB
vk3eht
Re: Active front end stats via udp.
Postby zhangchao » Sun Jun 25, 2023 2:43 pm
hi,
yes , the MOI have gcc and linker with header libraries .
if you need to talk more info about moi , you can add skype jack_2431 .
best regards!
zhangchao
Return to MOI Pro - AMD
