TBS5530 Full TS Capture
Postby stulluk » Thu Apr 20, 2023 9:44 pm
First of all, I couldn't find a dedicated section for TBS5530. Can you guide me if it exists? So that I can open this topic there.
I just bought a TBS5530 and using it with DVBS/S2 signals in Turkey. Device is connected to a Multiswitch (which supports both Diseqc1.0 and Diseqc1.1 spec) like this:
And I can also perfectly can use the device under Ubuntu 22.04 with Kaffeine APP:
I can scan & watch channels with Kaffeine.
However, I would like to use this device to capture Full Transport Stream, I mean whole TS file coming from a Transponder.
To achieve this, I used mumudvb as follows:
stulluk ~/mumu $
stulluk ~/mumu $  cat 11054v30000.conf
tuner=1
freq=11054
pol=v
srate=30000
coderate=auto
lnb_slof=11700
lnb_lof_low=9750
lnb_lof_high=10600
autoconfiguration=full
stulluk ~/mumu $
stulluk ~/mumu $
stulluk ~/mumu $  sudo mumudvb -c 11054v30000.conf --dumpfile new.ts -d
WARN:  Main:  You've decided to dump the received stream into new.ts. Be warned, it can grow quite fast
MuMuDVB Version 1.7.1
 --- Build information ---
Built with CAM support.
Built without transcoding support.
Built with ATSC support.
Built with ATSC long channel names support.
Built with support for DVB API Version 5.
Originally based on dvbstream 0.6 by (C) Dave Chapman 2001-2004
Released under the GPL.
Latest version available from http://mumudvb.braice.net/
Project from the cr@ns (http://www.crans.org)
by Brice DUBOST (mumudvb@braice.net)
Info:  Main:  Full autoconfiguration, we activate SAP announces. if you want to deactivate them see the README.
Info:  Main:  Full autoconfiguration, we activate PAT rewritting. if you want to deactivate it see the README.
Info:  Main:  Full autoconfiguration, we activate SDT rewritting. if you want to deactivate it see the README.
Info:  Main:  Full autoconfiguration, we activate sorting of the EIT PID. if you want to deactivate it see the README.
Info:  Main:  ========== End of configuration, MuMuDVB version 1.7.1 is starting ==========
Info:  Autoconf:  The autoconfiguration auto update is enabled. If you want to disable it put "autoconf_pid_update=0" in your config file.
WARN:  Logs:  saving_filename /var/run/mumudvb/mumudvb_generated_conf_card0_tuner1: No such file or directory
WARN:  Main:  Can't create /var/run/mumudvb/channels_streamed_adapter0_tuner1: No such file or directory
WARN:  Main:  Can't create /var/run/mumudvb/channels_unstreamed_adapter0_tuner1: No such file or directory
Info:  Main:  Streaming. Freq 11054000
Info:  Tune:  Using DVB card "TurboSight TBS 5530 DVB-T2/T/C/S/S2/S2x,ISDB-T,ATSC DVB-S/S2/S2X" tuner 1
Info:  Tune:  Tuning DVB-S to Freq: 1304000 kHz, LO frequency 9750000 kHz Pol:V Srate=30000000, LNB number: 0
Info:  Tune:  LNB voltage 13V
Info:  Tune:  DISEQC SETTING SUCCEDED
Info:  Tune:  FE_STATUS:
Info:  Main:  Card not tuned after timeout - exiting
stulluk ~/mumu $
So why it does not tune with MumuDVB ?
Can you also suggest to use another app that can work with Ubuntu, that allow me to capture Full TS for a given TP ?
stulluk
Re: TBS5530 Full TS Capture
Postby DVB » Fri Apr 21, 2023 2:55 am
You can try to add to conf:
delivery_system=DVBS2
modulation=8PSK
And now you're watching 8K:
KKKKKKKK
DVB
Postby stulluk » Fri Apr 21, 2023 5:53 am
DVB Wrote:You can try to add to conf:
modulation=8PSK
Thank you but I think my problem is related to configuration or a bug in mumudvb.
Please see: https://github.com/braice/MuMuDVB/issues/310
stulluk
Postby DVB » Fri Apr 21, 2023 7:10 am
If you're locking to wrong band - seemingly a DiSEqC port selection issue.
Remove delivery_system & modulation.
Are you sure about switch_input=1? This parameter has got count from 0, so if 42°E is on port 1/A, then expected value there is in fact 0.
Increase diseqc_repeat to 2.
Uncomment switch_type=C - try values C, U, B (U might be correct for your config).
KKKKKKKK
DVB
Postby stulluk » Thu Apr 27, 2023 4:25 am
DVB Wrote:If you're locking to wrong band - seemingly a DiSEqC port selection issue.
Dear DVB;
As you will see from here: https://github.com/braice/MuMuDVB/issues/310
I managed to lock to signal. However, this time I am getting "WARN: DVB: Error : DVR buffer overrun" and "TS Discontinuity Errors"
I couldn't get a reply from mumudvb for a week. Do you suggest me to use any other software for Full TS Capture ?
stulluk
