Continuity errors
Continuity errors
Postby martass » Mon Mar 27, 2023 1:24 pm
Hi, I bought an used TBS6285 card and installed it to my Ubuntu 20.04 Server with TVHeadend with no problem. Everything works fine except of huge amount of continuity errors. At the same time a cheap UBS tuner (MyGica T230Cv2) works with no errors. Therefore I am quite confident there is no problem with signal quality or TVH configuration. Is there a way of how to solve the problem (except of throwing the TBS card away)? Thank you.
martass
Re: Continuity errors
Postby smile » Tue Apr 04, 2023 11:00 am
Hi sir
the card is too old, 10 years ago. we already stop to update it.
it just support the close source drivers.
https://www.tbsiptv.com/index.php?route ... h=14&id=93
the drivers just only support kerenl version up to 4.10.
maybe you can test it on the windows, check it if has same problem.
Best Regards
smile
