TBS 5928 usb freezes system
Postby stinkefisch » Sat Feb 04, 2023 6:18 pm
Hi support team,
I own a TBS 5928 usb adapter which freezes my system.
I have built the drivers on a physical PC X64.
root@tvhead:~# lsusb
Bus 002 Device 010: ID 734c:5928 TBS Technologies China Q-Box II DVB-S2 HD
root@tvhead:~# modinfo dvb_usb_tbsqboxs2
filename: /lib/modules/4.15.0-202-generic/updates/extra/media/usb/dvb-usb/dvb-usb-tbsqboxs2.ko
license: GPL
version: 0.2
description: Driver for TBS QBOXS2-CX24116
author: Bob Liu <Bob@turbosight.com>
srcversion: 533BB7E5866E52F63B9ACCB
alias: usb:v734Cp5928d*dc*dsc*dp*ic*isc*ip*in*
depends: dvb-usb,rc-core
retpoline: Y
vermagic: 4.15.0-202-generic SMP mod_unload modversions
parm: debug:set debugging level (1=info 2=xfer (or-able)). (int)
parm: adapter_nr:DVB adapter numbers (array of short)
However if I try to scan the whole system freezes ?
No issues with another DVBSKY USB card on the same system.
Looks like a driver / firmware issue.
I have installed the firmware.
curl -L http://www.tbsdtv.com/download/document ... .0.tar.bz2 | tar -jxvf - -C /lib/firmware/
I can't find any other or newer firmware?
I get this on nearly ever transponder during the scan.
2023-02-03 10:36:18.238 mpegts: 10853.44H in Hotbird - scan no data, failed
2023-02-03 10:36:18.238 subscription: 00EB: "scan" unsubscribing
[ 32.783403] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 32.991471] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 34.892284] cx24116_load_firmware: FW version 1.23.86.1
[ 34.892299] cx24116_firmware_ondemand: Firmware upload complete
[ 35.204317] usb 2-1: DVB: adapter 0 frontend 0 frequency 0 out of range (950000..2150000)
[ 50.219349] tbsqboxs2: tbsqboxs2_set_voltage 0
[ 151.612295] tbsqboxs2: tbsqboxs2_set_voltage 1
[ 682.577086] tbsqboxs2: tbsqboxs2_set_voltage 0
[ 763.212190] tbsqboxs2: tbsqboxs2_set_voltage 1
[ 773.855682] tbsqboxs2: tbsqboxs2_set_voltage 0
[ 984.874421] tbsqboxs2: tbsqboxs2_set_voltage 1
[ 1189.443263] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 1189.443321] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
root@tvhead:/lib/firmware#
1/2 way through everything is freezing up and I have to disconnect the power from the TBS card and kill/restart the server.
Any idea please ?
stinkefisch
Re: TBS 5928 usb freezes system
Postby stinkefisch » Thu Feb 09, 2023 12:52 am
Any reply or idea on this please ?
stinkefisch
Postby steven » Thu Feb 09, 2023 3:56 pm
hi sir
which USB port you are using ?if you are using 3.0 please have a try using 2.0
thanks
kind regards
